Ongoing connection problem
hawkeye4
Message 41 of 41
Over the bank holiday weekend the connection dropped and reconnected cyclically every minute.
There is now a permanent connection. I can use email and connect to websites, though speed is slow, but am unable to watch any streaming services because of lack of bandwidth.
The connection and speed tests fail.
40 REPLIES 40
hawkeye4
Message 21 of 41
Hi Michelle
Thank you for the router. I have tried using it and it does not seem to have made a lot of difference but it is hard to tell as performance has been so variable throughout the day.
I did wonder if the problem lay with my laptop. I can now stream BBC iPlayer programs which I couldn’t before but not any of the other main channels. My laptop is an Acer Aspire3 and I am currently not able to run a TalkTalk speed test on it either with the new or the old router – when I select speed test I just get a blank page. I have tried other devices which seem to work better and am able to run speed tests on the original router with the following results:
HP laptop: 277ms / 2.0Mbps / 0.2Mbps and 193ms / 2.6Mbps / 0.2Mbps
iQuota laptop: 33ms / 11.0Mbps / 0.4Mbps
Amazon tablet: 63ms / 10.0 Mbps / 0.5Mbps
Could the problem be with my Aspire 3 and if so is there some check I can try to confirm it?
I can return the router to you but did not receive a return bag. If Yodel can collect it and provide a return label, I can pack it in the original box which I was careful to preserve.
Richard
hawkeye4
Message 22 of 41
Hi Michelle
The router has not arrived yet. Will test it and get back to you as soon as it arrives.
Richard
Message 23 of 41
Hi Richard,
Just checking back in to see how you're getting on?
Message 24 of 41
Hi Richard
hawkeye4
Message 25 of 41
Morning Michelle
Yes, that would be well worth a try.
Richard
Message 26 of 41
Morning Richard,
Thanks for confirming. Are you happy for us to send a replacement router to see how this compares?
hawkeye4
Message 27 of 41
Hi Michelle
No, the current router is the only one that I have: TalkTalk WiFi Hub (sagemcom) version FAST S364-3 TB
Richard
Message 28 of 41
Hi Richard,
Ok, do you have an alternative router that you can test with please? If not then we can send a replacement router for testing purposes to rule this out.
hawkeye4
Message 29 of 41
Hi Michelle
Just tried connecting router direct to BT main socket (via splitter) but still problems - website loading very slow and requiring reload, BBC iPlayer streaming still fails due to lack of bandwidth.
Richard
hawkeye4
Message 30 of 41
Hi Michelle
The main BT socket in my hall does not have a test socket. The main socket entry slot is by-passed with a cable attached inside to connectors. This cable then leads to a second  socket in my lounge, which has a splitter attached to it leading to my landline and TalkTalk router. This set-up has worked without problems for a number of years.
Richard
Message 31 of 41
I'm sorry to hear this. The line test is still clear, however I can see quite a few re-connections on the line. Does your main socket have a test socket please?
hawkeye4
Message 32 of 41
Thanks for your advice Gliwmaeden2
Telephone service okay. Not sure what constitutes noise on line. There is a low level cyclical noise of about 5Hz but noise level is no worse than I remember it.
Message 33 of 41
Staff need a reply re the quality of the phone line to help diagnosis of the issue.
If you don't have a handset, try to borrow one, plug it in and check. You could dial a freephone number to avoid costs.
Staff will be back after the weekend, @hawkeye4.
hawkeye4
Message 34 of 41
Update
Tried to upload 4 minute video clip from my laptop to my Google drive. Estimated time given as 45 hours.
Log on to BBC website now intermitent.
Message 35 of 41
Hi hawkeye4,
I can see that your connection has been very unstable but appears to have improved today. Are you experiencing any problems with your telephone service, any noise on the line?
Message 36 of 41
Thanks Keith
Profile updated
Message 37 of 41
Hi @hawkeye4
Message 38 of 41
Hi Keith
My TalkTalk router label states: TalkTalk WiFi Hub (sagemcom) version FAST S364-3 TB
The broadband drops out and shows the orange light before returning to white.
The router dashboard shows a speed of 8Mbps and guaranteed speed of 7Mbps. This dropped from 16Mbps on 21/8/24 to 8Mbps on 24/8/24.
The router version on the dashboard is SG4K100174
The dashboard 'My internet connection' page states internet connection status: disconnected ???
The device is connected wirelessly.
Richard
Chris-TalkTalk
Message 39 of 41
Hi hawkeye4,
In addition to answering Keith's questions can you also please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 40 of 41
Please can you elaborate by answering these questions?
  • Which make/model of router do you have?
  • Is it the broadband itself that is dropping (does the light change colour on the front of it)?
  • If you log into the router, what internet speeds does it display (normally in the main dashboard area)? How does this compare to your guaranteed minimum download speed?
  • Is this device connected via wireless or a wired (Ethernet) connection?
