Router firmware upgrade
mhumphrey78
Message 16 of 16
Can you pease upgrade my router firmware to 1.06t for router DG8041W
Mark
15 REPLIES 15
Message 1 of 16
Thanks for letting us know.
mhumphrey78
Message 2 of 16
I think it has been good, not been home much, I'll keep monitoring 👍
Mark
mhumphrey78
Message 3 of 16
Mark
Message 4 of 16
How have you found the connection/stability over the last 48hrs?
Message 5 of 16
Hi mhumphrey78
Ok thank you. Please let us know how the connection is over the next few days.
mhumphrey78
Message 6 of 16
Hi, it has been better but still dropping out, I had someone from talktalk change my configuration last night so will see how it goes,
Mark
Message 7 of 16
Hi mhumphrey78
How has the connection been since the firmware update?
Message 8 of 16
You're Welcome 🙂
mhumphrey78
Message 9 of 16
Thank you for your help 👍
Mark
Message 10 of 16
I've updated the router to v1.06t, see if this helps.
mhumphrey78
Message 11 of 16
Now is good there is no one home but it is switched on
Mark
Message 12 of 16
Hi mhumphrey78
I've completed a line test hasn't detected any faults.
When would be the best time to make the change to the router firmware?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
mhumphrey78
Message 13 of 16
My internet keeps dropping out, I found on another post that a router update might sort this out?
Mark
Message 14 of 16
Can I just confirm, are you experiencing any specific issues with your connection?
Skynet_TX
Message 15 of 16
Hi @mhumphrey78,
The support team should be able to help with this tomorrow.
Are you having the 'Kernel Panic' problem ?, as the only change in this version of firmware compared to 1.05t is the fix for that specific issue.
