Sagemcom F@st 266 Network WiFi Extender
lpowelllap
Message 34 of 34
Does anybody know how to get hold of one of these network mesh WiFi extenders? I have been pointed towards it in a separate Community discussion, but I don’t see it offered anywhere on the TalkTalk sites and information on the web generally is extremely sparse, even on Sagemcom’s own site?
33 REPLIES 33
threefins
Message 21 of 34
Hi @lpowelllap
How is your experience with the FAST266 Extender? Has it made any discernible improvement wrt range? I’m struggling to achieve a stable connection to an EV and EV charger, both are situated approximately 11 metres from my TT Sagecom FAST router, albeit there are a couple of internal walls to negotiate, one stud, one block and the house exterior wall/front door. I have a Cat 6 terminal approximately equidistant to router and EV/EV charger which I hoped to connect a second TT Sagecom router but hadn’t realised modem only/bridge mode wasn’t possible. Hence my interest in your ‘extender’ experience.
Message 22 of 34
Hi @lpowelllap
Log into the router, go into Advanced, then go into either the 2.4 or 5Ghz Wi-fi setup. In there is a WiFi Mesh tab (needs firmware version 158 minimum).  In the sub tabs is the Mesh specific stuff. Particularly go to the Devices tab, recognise each device
of yours by its MAC address and rename it to something meaningful.
Message 23 of 34
Thanks Keith - I connected it to the hub as per the instructions and then placed it in a central location in our home after checking that the indicator lights were as required (white-green-white). I assume there’s not much more to it than that?
Message 24 of 34
Hi @lpowelllap
If you have any problems or questions about the 266 as a mesh, just let me know.
Message 25 of 34
No Problem 🙂
lpowelllap
Message 26 of 34
F@st 266 extender arrived today - excellent service from TalkTalk after only ordering yesterday. Very quick and easy to set up.
Initial impressions are fairly neutral - hard to say at this stage whether it’s any better or worse than the previous TalkTalk powerlink extender, but I’ll give it a few days and see how things go……
Message 27 of 34
Ring the direct number for them:-
0345 1725157
Message 28 of 34
Thanks Keith. I can’t find any contact details for a ‘Loyalty Department’ as such?
Message 29 of 34
The Sagemcom FAST266 WiFi booster is available. I think if you contact the Loyalty department, you can buy one from there.
Message 30 of 34
Does it make any difference how close the device is to the router?
lpowelllap
Message 31 of 34
Generally it’s OK, but I have occasional speed issues and incidences of high ping and jitter which appear to be directly connected with the lower speeds. I already have a plug-in TalkTalk powerline extender, but I am told that a mesh extender such as the F@st 266 would likely give better results?
Chris-TalkTalk
Message 32 of 34
Hi Ipowelllap,
Are you experiencing problems with wifi coverage in your home?
Divsec
Message 33 of 34
Hi @lpowelllap not sure if they are still available, but the team here will advise when they return on Monday
Anonymous User
