Sagemcom Fast 5364 - can no longer access Advanced Settings in Hub
ComfortablyNumb
Message 67 of 67
I have noticed I can no longer access the router ADVANCED SETTINGS option when I log into the hub from my iPad (or iPhone) - despite being able to log into the dashboard. I was previously able to do this and I used to find it very convenient to have the ability to restart my router using one of my iOS devices without the need to go to the desktop computer. When I log in as Admin I get to see the dashboard but as soon as I click on the Advanced Settings option I get returned to login page (and so the perpetual cycle begins...).
I can, however, access these settings using my desktop computer - this happens to be connected via ethernet cable to the router.
Is this a new bug or is this a feature of the current software version?
My software version appears to be SG4K100174
66 REPLIES 66
Message 1 of 67
Hi @Airbud
As advised, please can you create your own topic and we can look into this for you.
Message 2 of 67
@Airbud
You have posted on an old and dormant thread. If you want help, please start your own topic.
Airbud
Message 3 of 67
Has anyone sorted this yet?
Airbud
Message 4 of 67
I get the same issue after resetting it
Message 5 of 67
Hi @ComfortablyNumb
Message 6 of 67
I think that you will find it was more like someone's sense of humour!
Message 7 of 67
If you feel that is likely to be the solution then please do. I am surprised by another comment here that the device could be past its “use-by” date - what is the expected life of a router like this that has no moving parts? My issue seems to be more software than hardware truth be told.
Message 8 of 67
Hi @ComfortablyNumb
I think we should send a new router, would you like me to arrange this?
Message 9 of 67
Ah, could be past it's "use by "date.  😉
Wait until Monday now until the support team are back online.
Message 10 of 67
This router was supplied to me in April 2019
Message 12 of 67
What firmware version is that running?
Message 13 of 67
Message 14 of 67
For what it's worth I just tested my old 5364: no issues across my MacBook, iPad, or iPhone.
Message 15 of 67
Hi @ComfortablyNumb
I've just tested all my apple devices this morning and have accessed advanced settings ok.
We are testing more apple devices at the moment with our Devices Team and I will keep you updated.
Message 16 of 67
Thank you. I've fed this straight back now and we'll keep you updated.
Message 17 of 67
My personal suspicion is that the issue is router originated and that access to these settings has been "restricted" somehow to direct wired devices. My iMac is connected via ethernet cable and from THAT device I have no problem accessing the advanced settings.
But, for what it is worth, my portable devices are as follows:
iPhone SE 3rd Generation - iOS 17.5.1
iPad 10th Generation - iPadOS 17.5.1
...I think this is irrelevant as I was experiencing the same behaviour on earlier versions of iOS/iPadOS - around the time the router firmware version "174" was deployed - prior to that I was able to access these settings from these devices. Does anyone know the date that "174" was released?
Message 18 of 67
Hi @ComfortablyNumb
Could you confirm the model of the devices again along with the IOS versions on both phone and iPad please?
Message 19 of 67
Hi @ComfortablyNumb
I will report this straight back to our Devices Team now.
Message 20 of 67
Message to all - have had firmware version SG4K100202 installed and has NOT resolved the original problem I reported - I still cannot access the advanced settings using iOS or iPadOS device.
Just a heads-up.
