Sagemcom Fast 5364 - can no longer access Advanced Settings in Hub
ComfortablyNumb
Message 67 of 67
I have noticed I can no longer access the router ADVANCED SETTINGS option when I log into the hub from my iPad (or iPhone) - despite being able to log into the dashboard. I was previously able to do this and I used to find it very convenient to have the ability to restart my router using one of my iOS devices without the need to go to the desktop computer. When I log in as Admin I get to see the dashboard but as soon as I click on the Advanced Settings option I get returned to login page (and so the perpetual cycle begins...).
I can, however, access these settings using my desktop computer - this happens to be connected via ethernet cable to the router.
Is this a new bug or is this a feature of the current software version?
My software version appears to be SG4K100174
66 REPLIES 66
Message 21 of 67
Message 22 of 67
Hi @ComfortablyNumb
I know the Devices Team are in the process of rolling out new firmware. I'm just checking if I can push this update to your router today.
I will let you know as soon as I have further information.
Message 23 of 67
There must be some information you can get on this? It is now middle of July - a YEAR after the issue was first raised.
Message 24 of 67
I'm sorry for the delay, we'll let you know when we have any more information
Message 25 of 67
It is now June and still no update!
Message 26 of 67
Hi Hawky123,
Please can you create your own topic and we'd be happy to look into this for you.
Hawky123
Message 27 of 67
I'm on the same firmware as you and I've noticed there is connection issued and packets is too high! with latency is too high too which means pings is too high too. Also kicked the other wifi devices off for no reasons. I thinks it is this software firmware itself. It is a new bug as my is same firmware and it showed my advanced setting. But communication is very poor
Message 28 of 67
We've had our weekly chat with our Devices Manager and it's looking like the next version of firmware for the Wifi Hub will be around the end of January or February.
Message 29 of 67
No update on the next version of firmware at the moment. I'll ask our Devices Manager on Thursday when we have our next catch up meeting.
ComfortablyNumb
Message 30 of 67
Any news on firmware update? Situation still the same as when first reported.
Message 31 of 67
@5CharactersNoSpaces, the remedy is to wait for the next firmware version, which could be many months away.
Message 32 of 67
I've found the following helps but intermittent success:
When you get into advanced settings and try clicking the gear icon for TalkTalk Wifi hub and get kicked out, instead of clicking the icon open a new browser tab and paste and go with this amended link http://192.168.1.1/0.1/gui/#/mybox
You'll notice the actual link is http://192.168.1.1/2.0/gui/#/mybox , but I was tinkering with older settings that worked and discovered the 2.0 directory as a change from previous bookmarks. It worked a while then ultimately booted me back to login but might be enough to get you in and do what you have to before it crashes out....
Message 33 of 67
Hi, I've searched through this and cannot see any remedy has been found yet.... I've just come across the problem myself and it's darn frustrating, get booted out of advanced settings soon as try to access. iPadOS and macOS. Have I missed it or is there still no remedy?
Message 34 of 67
Hi @ferguson
Not having any Apple products I can't say. TalkTalk do seem to have replicated the problem though, as they say that it will be fixed in the next firmware release.
Message 35 of 67
Hi @KeithFrench
I am not seeng any issues on macOS using Chrome. And as I mentioned earlier neither do I when using Safari on iPadOS. Most odd that this seems to be affecting some users, but not others. I don't use TalkTalk DNS servers, could that be a pointer?
Message 36 of 67
Hi @philipmarkevans
There are bugs in V174 accessing the advanced menu from iPhones & iPads, so this probably also applies to MACoS as well.
There is I  think a bug affecting UPnP, I cannot get it to work any more, but then again, UPnP is so highly insecure, that I always disable it anyway.
Message 37 of 67
Hi Keith,
Thanks for the prompt. I tried to get to the Port Forwarding screen and despite being under Advanced Settings, it now works from my Mac OS machine (access from initial Dashboard via 'See WiFi Settings' -> Advanced Settings -> Access Control).  Weird as it wasn't working earlier!
I can see that the firmware update removed the previous UPnP port forwarding rules, but after adding a manual TCP rule for port 32400, Plex remote access is working again.
So hopefully all good except for the (seemingly sporadic) issues accessing Advanced Settings.
Phil
Message 39 of 67
Hi @philipmarkevans
When you create your new thread for the plex issue, please include a screenshot of the port forwarding that I presume you are using & if you @mention me into the thread I will test it for you.
Message 40 of 67
Hi ComfortablyNumb
The issue with the advanced settings has been raised and will be resolved in the next firmware version.
@KeithFrench
