Samsung wifi issues with Eero.
LordBob
Message 4 of 4
Morning all.
Just wanted to run this by the community to see if there was any solutions before I contact TT.
We had TT full Fibre installed a month ago, 900, and it's brilliant on everything except my phone! PS5, Roku, Pixel, Switch, Vidaa tv, either wireless or wired work fine. My phone on the other hand is a pain! I have a Samsung Galaxy s23 ultra and before I had BT and it worked great but on TT and eero it's a nightmare. I'll use the phone and wifi and it'll be so slow so I run a Google speedtest and it will show 0.54 ish megabits persecond. I turn wifi off and on again and boom, 850 Megabits. It's so annoying! Most of the time now I'll turn wifi off and use 5g but currently they are upgrading the network here and I sit just between a 4g and 5g mast so that's a pain as well! I have done some Google searches and there seems to be issue with these phones but the so called 'fixes' don't work. So wondered if any of you wonderful community folk can shed any light on it?
Grumpy old man
3 REPLIES 3
Message 1 of 4
Is your phone in a different location to the others & is the WiFi band different? I can't really do much unless you take my offer to check your WiFi (it is free).
LordBob
Message 2 of 4
Thank you for the reply Keith. I had BT for years and never had any issue with my phone wifi. I have no issues with any other device on the TT network, my better halfs pixel and sons motorola work fine, mine just bugs out at 0.29mbps today for example. The ps5 is wired and works brilliantly and everything else is wifi. My phone can work again when turned off and on but often takes a couple of tries. It is to my mind a issue with the eero and samsung not liking each other. A few forums do describe problems but non really give a solution. That's why I thought I'd ask here. Could just be my phone and I'm due an upgrade March but obviously this issue could influence the brand I buy next time.
Grumpy old man
Message 3 of 4
Hi @LordBob
This is probably WiFi interference that is reducing the signal strength to your phone.
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
