Shocking Speeds
help1231
Message 24 of 24
I seem to be getting shocking  connection speeds late evening.!
This isn’t the first time!
Please help.
Help...!!!!!
23 REPLIES 23
Message 1 of 24
help1231
Message 2 of 24
Will do Debbie.
Help...!!!!!
Message 3 of 24
Hi help1231
No problem 🙂
Let us know how the connection/speed compares with this router.
help1231
Message 4 of 24
That would be great. Thanks. Debbie.
Help...!!!!!
Message 5 of 24
Hi help1231
Would you like me to send a replacement router for testing?
help1231
Message 6 of 24
Wired. No adapters nothing else connected. I don’t have another router to test with.
Help...!!!!!
Message 7 of 24
Thank you. This is showing high pings to the router. Just to confirm, did you run this test wired? Are you using any powerline adapters? Do you have an alternative router that you can test with please?
help1231
Message 8 of 24
16/03/22
19:05
Ping
5.5 Mbps
Ping
Min 24ms max 68ms Aver 42ms
Help...!!!!!
help1231
Message 9 of 24
Speed now
5M
terrible
Help...!!!!!
Message 10 of 24
help1231
Message 11 of 24
Yes just seen.
I will do later.
thanks.
Help...!!!!!
Message 12 of 24
I've included a Help Guide in one my last posts.
help1231
Message 13 of 24
How would I do that?
Help...!!!!!
Message 14 of 24
Ok, would it be possible to run the pings and trace routes please.
help1231
Message 15 of 24
Yes they were.
can’t do tests during day I’m out, usually run between 25-33 down
Help...!!!!!
Message 16 of 24
Thank you. Can I just confirm, were these results completed wired with only the one device connected? Please can you also run some more speed tests during the daytime too please so we can compare the results. Can you also run a wired ping and trace route when the speeds are good and also when the speed drops and post the results into the thread.
Run a Ping or Traceroute
help1231
Message 17 of 24
Repeat
23:39 1 hour later
7.9 down
6.7 up
Help...!!!!!
help1231
Message 18 of 24
Like you asked see attached.
shocking speed.
Can’t attach png so results are
14 03 22
10:39
6.4 Mbps download speed
7.3 Mbps upload speed
Help...!!!!!
Message 19 of 24
Great thank you 🙂
help1231
Message 20 of 24
Will do.
thanks.
Help...!!!!!
