Solid white light on router but no internet despite connection
Chris1C
Message 23 of 23
I’ve had no internet all day today. My router is showing a solid white light and my desktop is showing the wifi as “Connected, no internet”. I don’t have any internet either through wifi or through the wired connection through my Ethernet cable. Have spoken to TalkTalk who said it was a faulty broadband cable and they would send me a replacement but managed to source a replacement myself and still found the same issue. Have done almost all troubleshooting I can think of but I’m at a loss.
My router is the Sagemcom-FAST5364, if this is any help. Thanks in advance, could really do with some help on this one.
22 REPLIES 22
Message 21 of 23
Hey, thanks for the reply.
Yeah, sadly tried all of that with no luck. Didn’t realise you could even do the pin factory reset until today but went through the process and once everything was back up and running I just ran into the same issue again where it looked to be connecting but was giving no internet access.
Message 22 of 23
Have you tried rebooting the router?
Have you turned it off for 30 minutes and trying again?
If that does not work try a pin reset using the hole in the back of it.
Be aware though that if you have changed your broadband name or password, these will revert to the original router values, and you will need to change them again.
You are in the staff's queue for a response though, should this not work
