24-11-2024 02:43 PM - edited 24-11-2024 02:44 PM
I pay for 150mb down.
was getting 120mb (so happy enough) down for around 18mnths
contract renewed and my speeds dropped to around 70mb down.
eventually had a openreach engineer come out who confirmed it was not a issue in the property and then reset the line at the cabinet which fixed it.
a month or so later speed dropped again.
spoke to someone on chat who after a hour or so managed to reset something on their end (i had to go into a lot of detail that the engineer confirmed it wasnt a issue in my property) which fixed it for another month or so.
problem has came back again. support insist on sending a engineer. Although both times ive booked apparently there has beena technical issue and the appointment never went through.
In the latest case they even confirmed on the day that the engineer was on the way and only moved from that statement after the arrival window ended.
on 26-11-2024 08:53 AM
OK thanks. To investigate further we will need to arrange another engineer visit. If you'd like us to do this please let us know and we'll confirm some details with you
on 26-11-2024 08:29 AM
I’ve never actually had a landline phone plugged in and don’t own one.
i can say i very rarely see and drop outs with my broadband (as in I’ve had my 2 outages since moving here)
on 26-11-2024 07:41 AM
Thanks for that. Line test is passing but I can see that the sync speed is low. Are you experiencing any problems with your telephone service, any noise on the line?
on 25-11-2024 06:06 PM
Hi this is done
on 25-11-2024 08:25 AM
Hi niteninja1,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 24-11-2024 03:52 PM
OK, thanks for that. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
To save yourself time, please make sure that your community profile includes your first & last names, broadband phone number & if possible an alternative contact number. This can be done by clicking on your Avatar picture and then clicking on "My Settings" followed by:-
24-11-2024 03:50 PM - edited 24-11-2024 03:51 PM
Yep. Ive tried:
Ive done the 30mins reset steps.
replacing the router (i have a gfast modem) and running the speedtest on the router. Ive tried new ethernet cables.
as i say the openreach engineer has confirmed nothing within the property is the issue. It seems to be talktalk/openreach throttling the speeds as they can reset something on their end that fixes it.
i can directly tie the issues starting to the contract renewal time (i also note my minimum guaranteed download speed went from 120mb to 100mb)
on 24-11-2024 02:57 PM
Have you tried turning the ONT off for at least 30 mins? If still slow, not knowing the make/model of the router that you are using, can you connect a wired device to the ONT in place of the router & do a speed test from there?
