Speed to Router webpage
McParland57
Whizz Kid
Message 8 of 8
Service Status (talktalk.co.uk)
Is it just me having issues with e TalkTalk Speed to Router webpage?
I've only got it to run twice successfully since it's changed despite trying different devices.
I've been to a post-punk, postcard fair.
7 REPLIES 7
Message 1 of 8
Powering down the router for a full 30 minutes will reset the current session. Does the Service Centre error also happen if you use a different browser?
McParland57
Whizz Kid
Message 2 of 8
Just to clarify, I've swapped out routers, so the router was effectively off for several hours but the connection was back up after 5 minutes.  Do you want me to make sure there is no connection for 30 minutes?
Message 3 of 8
Could you switch your router off and leave it off for at least 30 minutes then switch back on and retest
McParland57
Whizz Kid
Message 4 of 8
I've tried running this page c25 times across various devices in the last 3 weeks and it's only completed twice.
It always "gets stuck" completing the last 10%.
This is using both routers so I don't think the failure is linked to devices being disconnected from the router.
Message 5 of 8
What problems are you having?
McParland57
Whizz Kid
Message 6 of 8
I did put in a new (reconditioned) router from TalkTalk and it's not been great.
Chris-TalkTalk
Message 7 of 8
Hi McParland57,
Are you currently experiencing any problems with your service?
