Speed
Pnokio
Whizz Kid
Message 26 of 26
It's gone slow again.
George
25 REPLIES 25
Anonymous User
Message 1 of 26
I've re-checked the connection stats and I can see that the sync speed has increased very slightly since we last checked. Hopefully DLM will continue to increase the sync speed over the next week.
Message 2 of 26
Same way as normal.
George
Anonymous User
Message 3 of 26
How have you found the connection/speed since your last post?
Anonymous User
Message 4 of 26
Thank you 🙂
Message 5 of 26
OK thanks, I will check it my self on occassion.
George
Anonymous User
Message 6 of 26
Ok. It's possible that the sync speed might increase again now that the line fault has been resolved. It can take 24-48hrs for DLM to make changes to the speed as it will monitor the stability of the connection first to ensure that this is stable. We'll check back in a few days to see if the speed has increased any further.
Message 7 of 26
My speed was higher approx 36mbps and was sent a Huawei router that I cant get to work.
George
Anonymous User
Message 8 of 26
Thank you for confirming. Is this what you were seeing previously before the speed dropped or was the speed higher than this?
Message 9 of 26
At 1300hrs on 10/08/2023 I am getting
30.04 mbps + 4.6 mbps
George
Anonymous User
Message 10 of 26
Good morning,
We've received an update to advise that Openreach have cleared the fault. I've re-run the line test again now and this is now showing clear. What speeds are you currently seeing at the moment please?
Anonymous User
Message 11 of 26
As the line test has detected a potential copper line fault then hopefully once this is resolved then the line should also be clear of any noise too as this will affect the broadband speed and stability. I'll check first thing tomorrow morning for an update on the fault. I just did a quick check and it's still with Openreach at the moment so hopefully there will be an additional update soon.
Message 12 of 26
When I answered your last question, I now realise you were talking about my house phone. As I don't use it, I called 03451 720088.
The line was very noisy and never got through as I was unsure of how to use it.
I also have this on my mobile phone, again I don't know how to.
George
Anonymous User
Message 13 of 26
That's great, thanks for confirming. As the line test has detected a possible copper line fault, I've re-raised this straight to Openreach and advised that this is a repeat fault. The engineer will then check the line outside the property. We'll monitor and will post back as soon as we receive an update back from Openreach.
Message 14 of 26
I can confirm, I am not experiencing any issues with the voice service such as noise on the line or no dial tone.
George
Anonymous User
Message 15 of 26
Thanks for confirming. I've re-run the line test now which is still detecting a potential external line fault, the connection looks unstable and the sync speed is varying. Would it be possible to confirm if you are experiencing any issues with the voice service such as noise on the line or no dial tone before we re-raise this back to Openreach for further investigation?
Message 16 of 26
I was sent a message that Openreach will be monitoring my line for next two days. It is not giving my advertised speed.
Image taken at 1000hrs 09/08/2023
George
Anonymous User
Message 17 of 26
Can I just confirm, have Openreach visited/been in contact?
Message 18 of 26
This is my latest post 08/08/2023 @ 16.10 hrs and the image shows its not been corrected yet.
undefined
George
Anonymous User
Message 19 of 26
No problem. Please let us know how you get on.
Message 20 of 26
I was given a link to TT using WhatsApp but will reply here as I find it easier.
George
Anonymous User
