Strange DNS failures
mitchgixer6
Chat Champion
Message 126 of 126
Hi all
I have been having issues with my connection recently, mainly slower speeds (still hitting 30mbs) and disconnects.
I have just spent 40 minutes on chat with the tech team trying to nail it down, but no errors with the line showing, suggested it may be wiring in my house but nothing here has recently changed.
I was just looking at my router setting and noticed some strange behaviur in the logs. Lots of DNS name resolution failures during the night when there would be no acces on my connection.
Anyone have a clue whats going on or if this could be the cause of my instability?
125 REPLIES 125
Message 1 of 126
No Problem 🙂
mitchgixer6
Chat Champion
Message 2 of 126
Hi Karl
Thanks very much for the update. That sounds like they managed to track down the problem and luckily also seems like it was a straightforward repair.
Fingers crossed the that keeps the connection stable from here on.
Cheers
Michael
Message 3 of 126
Engineer notes advise that they changed the E-side pair, so cables from Exchange side to cabinet, then re-terminated the connections at the cabinet.
mitchgixer6
Chat Champion
Message 4 of 126
Hi again
Good news to report, it looks like the disconnections I have been suffering with  for months have finally been resolved since the last engineer appointment.
I was however wondering if you are able to tell me what work was carried out by looking at the engineer notes? Don't get me wrong I'm glad that the problem seems to be fixed, but after 7 previous engineer visits where no improvement was made, I'm curious to find out what the actual fault was and how it was cured.
The last engineer I spoke to suggested the only fix would be to dig up my drive and replace the copper cable, so to have the problem fixed without the engineer even having to come into my house has triggered my curiosity...
Message 5 of 126
The line test is picking up a potential fault, so the engineer will check the line, if they need to access your home to carry out further checks they may contact you directly.
mitchgixer6
Chat Champion
Message 6 of 126
Hi Chris
Thanks for doing this. Can you please explain what this means though? I've already had 7 engineer visits with no improvement with the problem......
Chris-TalkTalk
Message 7 of 126
Hi mitchgixer6,
I've logged this to Openreach as a non-appointed task. This means that Openreach will investigate over the next 72 hours and may contact you directly if they need to access your home
mitchgixer6
Chat Champion
Message 8 of 126
Hi there
My connection is still the same, there has been no improvement. I have renewed my contract with TT so would like to book another engineer visit please.
Message 9 of 126
I'm sorry for the delay. How have you found the connection/speed since your last post?
Message 10 of 126
Hi mitchgixer6
Sorry that you are having problems
Best option would be to call the loyalty team on 03451720088 They will be able help.
Sorry for any inconvenience caused
Message 11 of 126
When you called and the voice prompt asked for the reason for your call did you say "I'd like to cancel," or
mitchgixer6
Chat Champion
Message 12 of 126
Message 13 of 126
You can only cancel by phone, unless you switch to another provider and ask them to take over your existing number, in which case they should contact TalkTalk on your behalf.
mitchgixer6
Chat Champion
Message 14 of 126
Is anyone on here able to help me put in my 30 days notice to cancel my contract?
I called the number today, and was passed bewtween 3 departments before finally getting cut off!
Message 15 of 126
Ok thanks for confirming.
mitchgixer6
Chat Champion
Message 16 of 126
Hi there
Yes I think I managed to cancel the engineer via live chat yesterday, although I've not had any confirmation from Openreach yet.
Message 17 of 126
Have you been in contact with the team directly?
mitchgixer6
Chat Champion
Message 18 of 126
OK, thanks very much for the advice
Message 19 of 126
It will be best to contact TalkTalk directly to ensure that it is cancelled in time as it will need to be done by 12 noon tomorrow, otherwise you may face a charge:
mitchgixer6
Chat Champion
Message 20 of 126
Hi again
I'm looking to cancel my engineer appointment for Tuesday the 1st between 8-1.
I have decided to to cancel my broadband with Talk Talk and wait until FTTP is available in my area.
