4 hours ago - last edited 3 hours ago
I have one device, a laptop, connected to the router via Wi-Fi 2.4GHz. It is definitely connected, because that is how I am accessing the internet to write this. 😊
However, when I go to https://support.talktalk.co.uk/, and click on 'Run a speed test', I get the response "There are no devices connected to your Wi-Fi network. To see the speed to your devices please make sure they are turned on and connected to your Wi-Fi." This has previously been working.
2 hours ago
Putting the router in the naughty corner with the power off for 30 minutes has made no difference. Scolding it for telling lies made no difference either. 😐
3 hours ago
Hi whatsgoingon0,
Could you try switching the router off for 30 minutes then switch back on and retest. Please let us know if this resolves the problem
3 hours ago
Moving this to the Broadband section, as the Lounge area doesn't always get staff support, @whatsgoingon0.
What package are you on?
[If it's Fibre65, is it FTTC or Full Fibre to the premises?]
