Thanks DLM, not
Divsec
Message 18 of 18
Hi I've enjoyed an excellent, for my area, rock solid service. No disconnections, no drop outs, nothing bad at all. This obviously upset DLM and it started tweaking 3 or 4 days ago, nett result 20% reduction in speeds.
I'm  going for a 30 minute reboot later today and hopefully this will get everything back to normal.
Why can't rural Norfolk have fibre?
17 REPLIES 17
Message 1 of 18
Hi Divsec
I just thought it would be worth checking this just in case this is causing any interference.
Divsec
Message 2 of 18
Hi @Debbie-TalkTalk yes I do, I'll move it from the room during the day.
D
Message 3 of 18
Hi Divsec
The Interference on the line is still being detected. I think this may be preventing DLM from increasing the speed.
Do you use cordless phone?
Divsec
Message 4 of 18
Morning all i hope you had a good weekend. No discernible change here, not a lot more we can do I suspect, other than the regular observed interference.
Message 5 of 18
Hi Divsec
I will check the connection stats again on Monday and I will post back on this thread.
Message 6 of 18
That's a new one @Debbie-TalkTalk ! In the same room are the deco 9 wired mesh and the samknows wired device. Also an Alexa dot which I've now moved to a different location. Be interesting to see if that improves things.
D
Message 7 of 18
Hi Divsec
I've had a look at the connection stats again and I can see that the sync speed is the same.
This has been detected - Regular Interference Observed Daily.
Is your router located near to any devices that could cause any interference?
Message 8 of 18
Hi both, no improvement overnight, let's see how the weekend goes. Hope you have a good one.
Message 9 of 18
Hi Divsec
Thank you. Hopefully DLM will increase the speed again.
Message 10 of 18
Thanks @Debbie-TalkTalk yes will do.
Message 11 of 18
Hi Divsec
Ahh no she's ok 🙂
We can see that the sync speed is starting to increase. Please can you leave the router powered up and I can check the connection stats again tomorrow?
Message 12 of 18
Oh don't say I've upset Michelle 🤐🤦.
Here's the sam knows data from the beginning of the month
10 May24.1 Mbps6.99 Mbps9.74 ms0.00224 %09 May24.6 Mbps6.95 Mbps10.4 ms0.15 %08 May26.4 Mbps6.83 Mbps10.4 ms0.0 %07 May26.3 Mbps6.82 Mbps10.4 ms0.0 %06 May26.2 Mbps6.82 Mbps9.87 ms0.0 %05 May26.4 Mbps6.86 Mbps10.3 ms0.0 %04 May26.4 Mbps6.86 Mbps10.4 ms0.00419 %03 May26.4 Mbps6.86 Mbps10.4 ms0.00205 %02 May26.4 Mbps6.86 Mbps9.62 ms0.00246 %01 May26.3 Mbps6.78 Mbps10.4 ms
And now creeping down towards 22mbps, all via Sam knows wired
D
Message 13 of 18
Hi Divsec
The line is in sync at 24.1mb. What speed were you previously receiving?
Message 14 of 18
Hi @Michelle-TalkTalk well that has shown no improvement. I'd be grateful if you could have  a look, but I'm not optimistic (not doubting your abilities)
D
Message 15 of 18
Message 16 of 18
Thanks @Michelle-TalkTalk wish my connection was as quick as your responses.
D
Message 17 of 18
I'm sorry to hear this. If there is no improvement following this then please let us know and we can take a look for you.
