on 16-06-2022 10:39 AM
I'm having trouble connecting to my work server through direct VPN. There seems to be some restriction and looks similar to issues that others have experienced. Again, I can connect successfully on a mobile hotspot - just the router that seems to restrict access.
Current version is SG4K100136
Can you help please
on 16-06-2022 11:25 AM
Excellent. I've also sent you a PM about our interaction today 🙂
on 16-06-2022 11:18 AM
Thanks Karl, I can connect successfully now.
on 16-06-2022 11:08 AM
Router should be updated, test the VPN now and let me know if it's ok.
on 16-06-2022 11:02 AM
Yeah not a problem, please do.
on 16-06-2022 10:56 AM
I need to make a change to your router - this will knock you offline for up to 10 minutes, is it ok to do this now ?
