VPN connection issue
PhilT71
Message 34 of 34
I have the following error message when trying to connect to my work VPN, this used to work fine with my old BT router.
"The VPN connection between your computer and the VPN server could not be completed. The most common cause for this failure is that at least internet device (for example, a firewall or a router) between your computer and the VPN server is not configured to allow Generic Routing Encapsulation (GRE) protocol packets. If the problem persists, contact your network administrator or Internet Service Provider."
Hope you can help.
33 REPLIES 33
Message 21 of 34
Hi Phil
I'm really sorry about this.
Let us know once the new router is connected.
PhilT71
Message 22 of 34
Hi Debbie,
I tried resetting it twice.
That's a shame but if nothing else can be done then please arrange for another router to be sent out.
Phil
Message 23 of 34
Hi Phil
Apologies for this.
If you have reset the router then I will need to send a replacement router.
Would you like me to arrange this?
PhilT71
Message 24 of 34
Morning Debbie,
I checked the router this morning and it had an orange flashing light on the front.  Not sure what is up with it, it was working o.k. on saturday.  I tried switching it off and on and pressing the factory reset for 10 seconds but it still had the orange flashing light.  I've had to come to work now so will have to investigate again when i get back this evening.
Any thoughts as to why the flashing orange light, could it be the phone line?
Phil
Message 25 of 34
Morning Phil
I still can't connect to your router.
Could you try factory resetting the router using the pin hole reset for ten seconds?
PhilT71
Message 26 of 34
Hi Debbie,
I should have checked my message before I sent it, I blame the autocorrect! The router is turned on and will still be on if u can do the update tomorrow.
sorry to mess you about.
Phil
Message 27 of 34
Hi Phil
Sorry for the confusion, I can only update the firmware when the router is switched on.
Could you leave the router switched on tomorrow morning and I can start the firmware update around 7am?
PhilT71
Message 28 of 34
Yes, it isn’t on at the moment. It would be great if u could get it updated today
Message 29 of 34
Hi Phil
Is the router switched on at the moment?
If the router is switched on and I connect then I will update the firmware today.
PhilT71
Message 30 of 34
Thanks for the reply. Do I need to be at home when you perform the update? If not, feel free to do it at any time, otherwise tomorrow evening would be best.
Message 31 of 34
Hi Phil
Apologies for this.
I will need to make a change to your router firmware, when would be the best time to do this?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
PhilT71
Message 32 of 34
Thanks for the reply, yes I have the sagemcom WiFi hub and I think it is just the standard win10/11 vpn but I will check with our IT guy on Monday.
Hopefully I will hear from the support team next week.
thanks
Skynet_TX
Message 33 of 34
Hi @PhilT71,
What model of router do you have ?
If you have the Sagemcom Wi-Fi Hub then this may be due to the firmware version the router is using.
What VPN software do you use, or is it the built in Windows 10/11 VPN ?
The support team here will be able to help, if you do have the Sagemcom they may be able to fix it by changing the firmware.
The Support Team won't be around now until Monday, but they should be able to respond to this post early next week to help.
Anonymous User
