VPN connection issue
PhilT71
Message 34 of 34
I have the following error message when trying to connect to my work VPN, this used to work fine with my old BT router.
"The VPN connection between your computer and the VPN server could not be completed. The most common cause for this failure is that at least internet device (for example, a firewall or a router) between your computer and the VPN server is not configured to allow Generic Routing Encapsulation (GRE) protocol packets. If the problem persists, contact your network administrator or Internet Service Provider."
Hope you can help.
33 REPLIES 33
Message 1 of 34
Hi Phil
I'm so glad to hear that this has been resolved.
Debbie 🙂
Message 2 of 34
Hi Phil
Glad our Team were able to help get your VPN connection back on Track.
PhilT71
Message 3 of 34
Hi Debbie,
Pleased to report my laptop connected straight to the vpn, the firmware change worked.  I can now work even when I am not in the office!😬 lol.
Thanks for all the help, hopefully things will run smoothly from now on.
Phil
Message 4 of 34
PhilT71
Message 5 of 34
Hi Debbie,
Thanks for the update, I will test the connection this evening when I get in from work and let you know.
Phil
Message 6 of 34
Hi Phil
The firmware has now updated, please can you retest?
Message 7 of 34
Hi Phil
Sorry for the delay. I've chased for an update on this and I will post back as soon as the firmware change has been completed.
Anonymous User
Message 8 of 34
No problem, we'll post back to confirm as soon as this has been completed.
PhilT71
Message 9 of 34
Hi Debbie,
Thats fine, lets hope it works.
regards
phil
Message 10 of 34
Morning Phil
Once the firmware has been updated I will post back on this thread to confirm.
PhilT71
Message 11 of 34
Yes please, fingers crossed it helps.
thanks
phil
Message 12 of 34
OK thanks Phil. I can only change this routers firmware version to v136, I can't roll it back to 2829t which is generally the one we change too for VPN issues. Do you want to give this a try?
PhilT71
Message 13 of 34
Hi Chris,
Still can't connect to the VPN, got the same error message as before:
Hope you can help.
Phil
Message 14 of 34
PhilT71
Message 15 of 34
Hi Chris,
Good point, I haven't been able to try the vpn connection yet, i will try it this evening when i get back from work and let you know.
Phil
Message 16 of 34
Hi Phil,
Just to confirm are you still experiencing the VPN issue with the new router on it's current firmware
PhilT71
Message 17 of 34
Hi Debbie,
The router was delivered this morning and I have installed it.  It seems to be working fine now i.e. the solid white light on the front.  Hope you can sort the vpn issue with the firmware update.
Phil
Message 18 of 34
Hi Phil
Let me know if the router arrives today and I can check the firmware.
Thanks again.
Message 19 of 34
PhilT71
Message 20 of 34
Hi Debbie,
No problem, these things happen.
Thanks for getting the replacement arranged.  I will message when the new router is connected.
Phil
Anonymous User
