VPN connection issues
morgano
Message 6 of 6
I am having problems connecting to my workplace VPN.
I see other users are having this issue and it is fixed by a Router firmware upgrade.
I am currently on firmware SG4K100136.
The VPN error message is: "The VPN connection between your computer and the VPN server could not be completed. The most common cause for this failure is that at least one Internet device (for example, a firewall or a router) between your computer and the VPN server is not configured to allow Generic Routing Encapsulation (GRE) protocol packets. If the problem exists, contact your network administrator or Internet Service Provider".
5 REPLIES 5
Message 1 of 6
Hi morgano
I'm so glad to hear this 🙂
I have also sent you a Private Message with a short survey.
morgano
Message 2 of 6
Debbie,
All OK now - thanks for sorting it out so quickly.
Message 3 of 6
Hi morgano
Thank you. The firmware has now been updated, please can you retest?
morgano
Message 4 of 6
Hi Debbie,
You can go ahead now thanks!
Message 5 of 6
Hi morgano
I need to make a change to your router firmware. Will it be ok if I do this now or at some point this morning?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
Anonymous User
