VPN connection stopped working
on 20-01-2022 04:32 PM
Message 25 of 25
my VPN connection to work has stopped working and I am getting a message “A connection to the remote computer could not be established, so the port used for this connection was closed”. It was working fine until yesterday and hasn’t worked since. I am able to connect using other networks so guess this must be to do with my router. I have had the router a couple of years and all has been fine.
Please can you help as I need to be able to work from home and can’t at present.
Julian
Labels:
- Labels:
VPN
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
24 REPLIES 24
on 26-01-2022 11:52 AM
Message 1 of 25
Glad our Team were able to help 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-01-2022 11:49 AM
Message 2 of 25
Hi Debbie,
The new router arrived and allowed the VPN to work. I will check again tomorrow when I am next working from home but looks like this could be the problem solved. If it all works tomorrow then I will get the other routers returned. Many thanks for your swift response and help in resolving this issue.
thanks again
Julian
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 24-01-2022 08:28 AM
Message 3 of 25
Hi Julian
No problem 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 24-01-2022 08:24 AM
Message 4 of 25
Hi Debbie,
okay that’s great thanks.
Julian
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 24-01-2022 08:19 AM
Message 5 of 25
Hi Julian
No sorry, it's related to the current FW already on the new router.
The Huawei hub is on its way and you should receive this within the next 24-48hrs.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 24-01-2022 08:12 AM
Message 6 of 25
Hi Debbie,
yes that would be great thanks. The difficulties you are having wouldn’t be because I am connected through the router at the moment?
Julian
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 24-01-2022 08:10 AM
Message 7 of 25
Hi Julian
I'm having some issues with the FW and the new router. I think we should send a Huawei hub and a returns bag for the routers you have now. Will this be ok?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 24-01-2022 07:53 AM
Message 8 of 25
Hi Debbie,
New router connected ready for you to change the FW.
Julian
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 24-01-2022 06:37 AM
Message 9 of 25
Hi Julian
Would you prefer to keep the new router (because of the stand on your old one?) If you could connect the new router then I can make a change to the FW.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 23-01-2022 10:35 AM
Message 10 of 25
Hi Debbie,
the new router arrived and was another Sagemcom. I fired this up but this wouldn’t allow the VPN to connect. I have reconnected my old router as before and this still allows me to connect over the VPN. Whatever you did to the firmware seems to have done the trick for now thanks. However as the new router doesn’t work for the VPN shall I send this back?
Julian
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 22-01-2022 08:48 AM
Message 11 of 25
Hi Julian
That's great, thanks for letting us know 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-01-2022 05:51 PM
Message 12 of 25
Hi Debbie,
the changes that you have made now allow me to connect on the VPN.
I will let you know which router arrives and whether it is worth swapping (my current one does have a dodgy stand so may want to swap anyway)
many thanks
Julian
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-01-2022 08:38 AM
Message 13 of 25
Hi Julessacha
Yes the router is still on its way. Please let me know which make and model of router you receive.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-01-2022 08:29 AM
Message 14 of 25
Thanks Debbie, I will try again later. I presume the router is still being sent as this appears to be the solution in most cases?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-01-2022 07:54 AM
Message 15 of 25
Hi Julessacha
Ok, I've made the change. Please can you retest this evening and let us know how you get on.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-01-2022 07:34 AM
Message 16 of 25
Hi Debbie, I am not particularly IT literate so I am not what you mean by latest DNS fixes or how you change the firmware. I am not home today so won’t know if any changes will have worked until this evening, but yes you can try if you think it will solve the problem.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-01-2022 07:10 AM
Message 17 of 25
Hi Julessacha
I can see that a router has been ordered but it's not showing yet which make and model it was.
We can try a change to the firmware but this wont have the DNS fixes in, would you like me to try this?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-01-2022 10:55 PM
Message 18 of 25
Even if they did send another Sagemcom, it probably won't have that version of firmware on it, and with any luck the issue with this new version of firmware might be resolved before your new router tried to upgrade to that version again.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-01-2022 10:31 PM
Message 19 of 25
They didn’t ask which router I had. I would hope that they would know not to send another Sagemcom but I guess when an advisor picks this thread up tomorrow they should be able to see which router has been sent?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-01-2022 09:35 PM
Message 20 of 25
Yep, as long as they send you a router of a different model that should fix it.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- IMAP/POP3 has suddenly stopped working in Email
- Email no longer works with iOS Mail. Only webmail. in Email
- Broken phone line and just need a BT repair person to come and re-attach the cable in Broadband
- Internet conection dropping out/unable to use talk talk conection test. in Full Fibre
- Back Again with a Internet Speed Problem in Full Fibre
