WAN DHCP client (1) stopped
unhappycustome1
Message 32 of 32
My home broadband connection has been dropping on the WAN link multiple times a day for the last few months. I have reported it many times to talk talk through the support chat service and still nothing has been done. I work from home and so many of my meetings have been interrupted. I am really at the end of my temper and do not know what to do.
When I look at the router logs, at the time the problem occurs I get the message
and the LED on the router goes from white to orange for about 3-4 minutes.
I am also getting lots of
ErrorDNS
DNS name resolution failure (_dns.resolver.arpa)
occurring every few minutes, sometimes more frequently.
I have raised multiple support cases with the chat and nothing ever gets resolved
PLEASE PLEASE HELP!
31 REPLIES 31
Message 1 of 32
Line test is passing but your sync speed is quite low and I can see that the connection is dropping. Would you like us to arrange another engineer visit?
Message 2 of 32
Thank you.
Another observation, after the Openreach engineer visited a few weeks ago and made changes the noise margin on the line (reported by the router statistics) increased. I assume the engineer increased the signal level.  However I just checked and it looks like the noise margin returned to its original level that it was a few weeks ago, here are the current stats
Line 1
Downstream Upstream
Actual Rate [Kbps] 23583 5940
Maximum Rate [Kbps] 22892 5940
Noise Margin [dB] 0.00 3.00
Attenuation [dB] 25.50 0.00
Power [dBm] 10.10 6.80
You can see the noise margin is very low again. I am wondering if some settings have been changed at the exchange again.
Gliwmaeden2
Message 3 of 32
I'll re-escalate this for you, @unhappycustome1.
Staff will reply after the weekend.
Message 4 of 32
Hello
Our ADSL connection is still dropping about once a day, at this time all connectivity is lost and any calls underway get dropped for about 3 -4 minutes until the connection comes back again. I always see this in the router logs
26.11.2023 09:38:43 Info DHCPC WAN DHCP client (1) started
26.11.2023 09:38:41 Info XDSL VDSL connectivity is up port 1
26.11.2023 09:37:23 Info LETH An Ethernet port is now connected (2/10/FULL)
26.11.2023 09:37:17 Info LETH A device has been disconnected from an Ethernet port (2)
26.11.2023 09:36:40 Warning DHCPC WAN DHCP client (1) stopped
26.11.2023 09:36:39 Info XDSL VDSL connectivity is down port 1
It is better than a few weeks ago when it was dropping multiple times every day.
Message 5 of 32
I've checked the logs, there were a couple of two minute drops on the 12th, non on the 13th or 14th and a couple yesterday. When there are two drops it seems to be one in the morning and one in the evening. Is your router currently connected to your test socket?
Message 6 of 32
Hello
I just want to report that whilst our XDSL connection stability has significantly improved since the Openreach engineer made the changes the connection is still dropping approximately once a day.   The router's LED changes from white to orange for a couple of minutes then back to white. I get a lot of these DNS lookup errors in the logs, it happened again about half an hour ago:
15.11.2023 19:38:27 Error DNS
15.11.2023 19:38:06 Error DNS
DNS name resolution failure (4a921d4f1868fd6664711ea0010f65cd-adf0901f1861.cdn5.forter.com)
15.11.2023 19:18:22 Error DNS
15.11.2023 19:15:02 Error DNS
Message 7 of 32
Thank you for the update. As advised, if you could create a new topic in the Billing Section please then our colleague Arne will be able to assist with this.
Message 8 of 32
@unhappycustome1, when sent out by customer service agents (rather than forum support staff) they seem to carry a charge.
Post in the billing section for Arne to take a look, with reference to this thread. He will be back after the weekend.
Message 9 of 32
Hello Karl
I am pleased to report that our ASDL connection to the exchange has been much more stable this week. The connection was dropping several times a day for the last few months but this last week since Openreach made adjustments it has been much more stable.
There is just one problem though, Talk Talk has now added an extra £34.95 to our monthly bill for the supply of a wifi hub. I can only assume this must be a mistake, rather than being charged extra I would have expected to be receiving compensation for the terrible broadband service we have had since August!  Can someone please look into this and remove it from our bill?  Yes, TalkTalk did send a replacement router to test and yes I returned the old one in the plastic postage bag provided.
Thank you
Message 10 of 32
Glad the engineer has made some adjustment, monitor this week and let us know how it goes later in the week.
Message 11 of 32
Hello all
The Openreach engineer visited yesterday and ran tests on our line. The signal-to-noise ratio was low (as I pointed out 8 weeks ago) and he made some adjustments, I assume boosting the signal from the exchange, so the noise margin is now 6dB (was 3dB).
He also did a DLM reset.
So far the connection has been up for 24 hours. I think we need to give it several days to see if better.
Thanks for organizing the Openreach visit. It's just a shame it took 8 weeks to get to that point.
Message 12 of 32
Excellent, Openreach have confirmed the appointment here also.
Message 13 of 32
Hi @unhappycustome1
please confirm acceptance of engineer conditions so the appointment can go ahead.
Message 14 of 32
Can you confirm your ok with the engineer charges so I can relay this to Openreach, or they will not visit.
Message 15 of 32
HI
PM sent regarding openreach booking.  Can you reply and confirm you are ok with engineer conditions.
unhappycustome1
Message 16 of 32
Hopefully it worked that time.
Message 17 of 32
I'm sorry, but we have not been able to Verify account identity with the details provided.
If you do not have a telephone password set, you can do this via My Account
Please also see our Article : Setting Up a Telephone Password If you require assistance with this.
If you do have a Telephone Password set, you can request an email reminder from withn My Account. Simply Click your Name at the top of right of the screen, select Profile & Settings then My Details & Passwords from the drop down menu.
Scroll down and select Telephone Password. This will then give an option to send the password to your registered email address.
Message 18 of 32
Sent you another PM 🙂
Message 19 of 32
Hello Karl,  Many thanks.  I just replied to the secure link.
Message 20 of 32
I've sent you a PM to confirm some info before we look to arrange an Openreach engineer for you.
