Lost connection Wired system
martynwjones
Message 16 of 16
Hello Team,
I am getting intermittent outages on my broadband wired connection (I am not using wireless).
I have looked at my logs and I see this:
11.11.2024 21:09:05ErrorDNS
DNS name resolution failure (221.144.123.52.in-addr.arpa)
11.11.2024 21:09:03InfoSYS
TR-069 connectivity to (acs.talktalk.co.uk) has been closed
11.11.2024 21:09:02ErrorDNS
DNS name resolution failure (238.197.225.165.in-addr.arpa)
11.11.2024 21:09:02InfoSYS
Modem login was successful
11.11.2024 21:09:00InfoDHCPC
The WAN DHCP client IP address 81.170.62.191
11.11.2024 21:08:27InfoDHCPC
WAN DHCP client (1) started
11.11.2024 21:08:25InfoXDSL
VDSL connectivity is up port 1
11.11.2024 21:07:55WarningDHCPC
WAN DHCP client (1) stopped
11.11.2024 21:07:55InfoXDSL
VDSL connectivity is down port 1
Can you take a look for me please?
I have checked all the wired connections and they look good.
Mart
Martyn Jones
15 REPLIES 15
Message 1 of 16
Hi Mart @martynwjones
That's great news, thanks for letting us know 🙂
I've sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 2 of 16
Hello Team,
Installed the new router on the weekend.  So far so good!
No drop outs at all.
Thanks for your help!
Mart
Martyn Jones
Anonymous User
Message 3 of 16
Hi Mart,
How are you getting on?
Message 4 of 16
No problem 🙂 @martynwjones
The router is on its way, please can you use the new cables and filter that arrive with the router too.
Please allow 24-48hrs for this to arrive. Let us know how the connection compares.
Message 5 of 16
Yeah - lets try that.
Thank you for your quick response (as always)
Mart
Martyn Jones
Message 6 of 16
Message 7 of 16
Well - that's good news!
Not had a router recently
Martyn Jones
Message 8 of 16
@martynwjones
All done 🙂
The line test is now clear. Have we recently sent you a new router?
Message 9 of 16
Morning @martynwjones
Perfect, I will start the line test now and post back once it's completed.
Message 10 of 16
I have removed the faceplate - please let me know when I can reconnect 🙂
MArt
Martyn Jones
Message 11 of 16
The line test is still detecting a loop fault. Would it be possible to remove everything from the line (including face plate) for 15 minutes so I can run a line test with everything removed?
Message 12 of 16
Yes, connected directly to the test socket.
Mart
Martyn Jones
Message 13 of 16
Hi @martynwjones
The line test is also detecting a loop fault and this can often be caused by internal wiring or equipment connected to the line.
Is the router connected at the test socket at the moment?
Message 14 of 16
Hello - thank for getting back to me.
No, we haven't been using the landline for a while now.
Mart
Martyn Jones
Message 15 of 16
Hi martynwjones
The line test is detecting a potential fault with the landline service. Do you use your landline for making calls?
Anonymous User
