WIFI Channel Optimization. Unable to enable 2.4gHZ.
welshman77
Message 6 of 6
Unable to use/connect various devices that require 2.4GHZ,  router configuration will not allow me to enable this.   Research found that has been fixed for other customers by disabling WIFI Optimisation.   Please disable.
5 REPLIES 5
Message 1 of 6
Hi Welshman77,
I've ordered a replacement router, it should be with you within a couple of working days
Message 2 of 6
Cheers Keith appreciated the efforts and the advice.
Message 3 of 6
Then the router must be faulty. I have asked one of TalkTalk's support to pick your thread up and replace it for you.
To save yourself time, please make sure that your community profile includes your first & last names, broadband phone number & if possible an alternative contact number. This can be done by clicking on your Avatar picture and then clicking on "My Settings" followed by:-
Message 4 of 6
Hi Keith,  already performed factory reset, no joy.
Message 5 of 6
That will not work for two reasons:-
  1. WiFi optimisation does not have the power to disable a band, only to alter its channel & other WiFi parameters.
  2. Even if it did, the TalkTalk staff here can no longer disable WiFi Optimisation.
Please perform a Factory Reset on your router.
