WIFI HUB NO ETHERNET CONNECTION TO INTERNET
tbog007
Message 5 of 5
Hello community,
Like other posts around here, my  ethernet connection is not working when connected to the router.
I tried CAT5 and CAT6 cables.
The cables have been tested and are working.
WIFI is working fine on any device.
I tried also the cable that was provided with the router that is a CAT 5E.
The admin page shows that there is a connection on that port but no traffic on it.
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Ethernet gear icon
Under Windows settings -> Network & Internet -> Ethernet it shows it's connected to the router (displays it's name) but says "No internet".
undefined
Tbog
4 REPLIES 4
Message 1 of 5
glad to hear that you got to the bottom of this.
tbog007
Message 2 of 5
Hello, Thank you for getting back to me.
After some additional troubleshooting last night - yes resetting the router was part of this additional testing, I was able to find a laptop where the newly created cat6 cable actually worked and therefor concluded that the issue I had was that the other laptop and the desktop did not have appropriate ethernet drivers.
After updating the drivers for the desktop it finally connected and I was able to use the internet through the CAT6 cable.
Cheers,
Tbog
tbog007
Message 3 of 5
Cheers,
Tbog
Anonymous User
Message 4 of 5
I'm sorry to hear this. Have you tried resetting the router and then re-testing this again? Do you have an alternative router that you could test with please?
Anonymous User
