WIFI OPTIMISATION
Chris1012
Message 134 of 134
I recently switched to Talktalk broadband and I'm having issues with WIFI optimisation and channel hopping causing certain devices to disconnect from the WIFI network. From reading these pages I understand that a Talktalk employee can disable this feature on my router? Please can this be actioned?
133 REPLIES 133
Message 61 of 134
Hi Chris,
I have had one further VDSL dropout overnight at ~1am. I assume this is the DLM trying to sort out the connection after the numerous dropouts on Wednesday night/Thursday morning. Yesterday I spoke to one of my neighbours who is with BT. He said that they had '1-2 dropouts for a few minutes at ~9pm on Wednesday'. This agrees with when my dropouts started on Wednesday evening, however, I then had ~24 dropouts over the next 9 hours! Surely, 'mass event' or no 'mass event' my experience cannot be 'normal' and indicates a fault somewhere? If my experience is 'normal' then you would be inundated with complaints every time a 'mass event' happened! The recent dropouts are just one of many that have happened over the past month, they all can't be caused by 'mass events'.
Message 62 of 134
Although as the Openreach engineer told me, unless a dropout happened whilst a test was being performed they would be very unlikely to detect the fault. Since the ONLY thing connected to my master socket is the Talktalk router, the cause of the dropouts can only be the router/Openreach phone line/Openreach or Talktalk equipment in the cabinet/exchange. We tried a second Talktalk router (which I have since returned) and that didn't solve the dropouts. This only leaves the Openreach phone line and Openreach or Talktalk equipment in the cabinet/exchange.
Message 63 of 134
Yes I agree that something must be causing the disconnections, the line test is just showing that there are no faults detected on the Openreach network.
Message 64 of 134
Hi Chris,
I can't understand how there can be 'no problems' when the connection dropped ~24 times in a 12 hour period, surely that in itself means there is a problem somewhere? I have no idea what a 'mass event' is and whether that would cause the issue. Although I have been told this before, but it can't be responsible for 60+ dropouts I've had over several weeks. I have had no more dropouts since ~6am. I will give it another 24 hours, but if I get anymore dropouts I will immediately report back so that you can arrange another engineer visit.
Message 65 of 134
OK thanks. The line test does show that there are no problems found on the Openreach network but the performance of the service may be impacted by a recent mass event. We can arrange another engineer visit but I think it's probably worth giving it another 24 hours to see if the connection stabilises before doing this
Message 66 of 134
Hi Chris,
Yes, the router has been reconnecting (flashing orange/white light) many many times over the past ~12 hours (well over 20 at the last count from the log). The only thing connected to the master socket is your router, I don't use the phone connection so can't comment on that.
Message 67 of 134
Hi Chris,
I'm sorry to hear that the problem has got worse, Line test is showing a lot of reconnections over the last few days, are you experiencing any problems with your telephone service, any noise on the line?
Message 68 of 134
Hi Michelle,
It's been just over a week since the engineer visit. I had a couple of VDSL dropouts over a few nights, but I put those down to the stabilisation period and the DLM. However, from last evening until this morning (5am) I have had 22 VDSL dropouts! The internet was unusable for ~ 2 hours yesterday evening and has been virtually unusable this morning! Obviously the engineer has not fixed the problem of the VDSL dropouts and they are now getting significantly worse. This issue has been ongoing for nearly a month and my patience is wearing thin. Please could you escalate this to a formal complaint so that it can be resolved once and for all.
29.05.2024 20:45:42
Info
XDSL
VDSL connectivity is down port 1
29.05.2024 21:05:07
Info
XDSL
29.05.2024 21:09:09
Info
XDSL
29.05.2024 21:10:01
Info
XDSL
29.05.2024 21:11:12
Info
XDSL
29.05.2024 21:13:57
Info
XDSL
29.05.2024 21:59:25
Info
XDSL
29.05.2024 22:17:51
Info
XDSL
30.05.2024 01:11:00
Info
XDSL
30.05.2024 02:23:41
Info
XDSL
30.05.2024 02:52:40
Info
XDSL
30.05.2024 02:53:31
Info
XDSL
30.05.2024 03:24:51
Info
XDSL
30.05.2024 03:40:10
Info
XDSL
30.05.2024 04:28:18
Info
XDSL
30.05.2024 04:29:57
Info
XDSL
30.05.2024 04:46:33
Info
XDSL
30.05.2024 04:50:54
Info
XDSL
30.05.2024 04:51:50
Info
XDSL
30.05.2024 05:35:54
Info
XDSL
30.05.2024 05:36:51
Info
XDSL
30.05.2024 05:38:50
Info
XDSL
Message 69 of 134
Hi Chris,
I understand. It was decided in the last month and we have been feeding back to the team on this. Please let us know how the alternative router compares. If it is still happening then we can pass the dates and times to the team to see if they can see a specific issue causing issue and ask what the solution will be.
Message 70 of 134
Hi Michelle,
So this is a recent decision since you were able to turn off wifi optimisation for me on the 19 April? I will try the previous router to see if wifi optimisation is still disabled. I disagree with the team - for my setup, which is pretty basic, we proved 100% that disabling wifi optimisation completely fixed the problem with my 3D printer becoming unresponsive on the wifi and needing a restart (something I never had with my previous ISP's router). I will look at collecting dates/times when this happens, but this and documenting all of VDSL dropouts are taking way more of my time than they should! Surely the broadband and wifi should just work, it always has with previous ISPs!
Message 71 of 134
Hi Chris,
Thanks for confirming. Unfortunately we no longer have the option to switch wifi optimisation off as the team has advised that by switching this off it will cause more overall connection problems. Would it be possible to provide a few specific dates and times when this is happening and we can refer back to the logs on our side.
Message 72 of 134
Hi Debbie,
Within a few meters. The engineer didn't do anything at all with the router wifi, he only worked on the Openreach line. As I said previously in this post (see message 47 here), once you had disabled wifi optimisation on the old router ALL of my wifi connection issues with the 3D printer went away. They only returned when I plugged in the replacement router to try to solve the VDSL dropouts.
Message 73 of 134
Hi Chris
How far away is the router from the laptop and 3D printer?
Since the engineers have completed the work on the line have there been any improvements with the connection to these 2 devices in particular?
Message 74 of 134
Hi Debbie,
My 3D printer, which was the whole reason I started this post! I also had a problem with a computer (Macbook pro) that was 'kicked off' the network, despite the router showing it as connected (the same issue I had with the 3D printer). Restarting the wifi on the Macbook solved the connection, but it happened again when the wifi optimisation did its channel hopping thing. I've also been getting the 'WiFi security settings have been successfully saved' message in the router log that has been linked to devices being 'kicked off' the network (just to be clear I haven't made any changes to the wifi to cause this line in the log). When the 'WiFi security settings have been successfully saved' message appears multiple devices are forced to disconnect/reconnect to the wifi and it seems to be this behaviour that causes some devices to not connect correctly (I never had any of these issues with my devices and previous ISP routers, so it's not the devices causing the problem, it's the Talktalk router).
Message 75 of 134
Hi Chris
I can check but it may have switched back on again.
What wifi devices are experiencing issues?
Message 76 of 134
Hi Debbie,
Yes, I have a return bag and label.
If I switch back to the first router (where you disabled wifi optimisation) will the wifi optimisation still be disabled? I've had wifi connection issues over the past ~week with the second router due to the wifi optimisation being turned on (the same issues I had with the first router before you turned wifi optimisation off).
Message 77 of 134
Hi Chris
Thanks for letting us know.
Did you receive a returns bag to return the older router?
We can no longer switch off wifi optimisation on the line.
Message 78 of 134
Hi Debbie,
The engineer came yesterday afternoon. He replaced the master socket and also found problems in a junction box in the road (corroded connections) and at the street cabinet (my 'profile' had been setup incorrectly, presumably when I joined Talktalk). He corrected both of these problems and said that because of the profile reset I'm now on a 2 week stabilisation protocol. Hopefully fixing these problems will correct the VDSL dropout issue, but I won't know for sure until at least several days have passed since they were intermittent.
Since the second router didn't solve the VDSL dropouts I presume you would like one of the routers returned? If so, please could you disable wifi optimisation on the router that is currently connected so that I don't have to switch over routers and interrupt the connection whilst it is stabilising? I can then return the first router.
Message 79 of 134
Hi Chris
Thank you. I will check in again with you after the engineer visit.
Message 80 of 134
Hi Debbie,
Thanks for letting me know, I'll be sure to be in! I've just received this email from Talktalk - I assume this is related to tomorrow's appointment, but no date is given. It just says 'Repair_Engineer_VisitDateRepair_Engineer_VisitDate'!
Engineer appointment confirmation
Your engineer will visit you on Repair_Engineer_VisitDateRepair_Engineer_VisitDate between 1:00pm and 6:00pm.
If your issue is fixed, or you need to rearrange or cancel your appointment, please contact us 12:00pm, one working day before your appointment date to avoid a missed appointment fee of £75.00.You can chat to us via
here.
Don't forget to keep an eye on any updates via 'My Active Faults' in My Connection,
here.
Your TalkTalk team
