WIFI OPTIMISATION
Chris1012
Message 134 of 134
I recently switched to Talktalk broadband and I'm having issues with WIFI optimisation and channel hopping causing certain devices to disconnect from the WIFI network. From reading these pages I understand that a Talktalk employee can disable this feature on my router? Please can this be actioned?
133 REPLIES 133
Message 41 of 134
Hi Chris,
I've checked the connection history for the last few days and most of the time the connection looks really stable with a very low error count but then it just drops the connection now and again for about a minute. Is the router connected to a multi-socket electrical extension lead shared with other devices or connected directly to a wall socket?
Message 42 of 134
Hi Chris,
Unfortunately I spoke too soon since the VDSL dropouts have returned. Since my last post I have had another 7 dropouts at random times over the past few days. Hence, whatever the engineer did on the 1st June seems only to have been a temporary fix and the problem has now returned!
Chris-TalkTalk
Message 43 of 134
Hi Chris,
That's great news, thanks for the update 🙂
Message 44 of 134
Hi Chris
It’s been over two weeks since the second Openreach engineer visit on the 1st June. There were several VDSL dropouts in the first few days following the visit, but over the past ~10 days the line has been stable. This is a significant improvement compared to the whole of May where the line would typically drop several times (or more) each day. I can only assume that the additional corroded line connections found by the second engineer were the cause of the dropouts. I will continue to monitor the router log and will post back here should the line dropouts return.
Anonymous User
Message 45 of 134
Hi Chris,
We've made a note of the tracking so you shouldn't be charged.
Message 46 of 134
I would expect a 48 hour service to take less than ~10 days, even with a bank holiday weekend! I just don't want to end up with a £50 fee added to my bill for 'not' returning the router (I have proof of posting/collection).
Message 47 of 134
@Chris1012, mine took 6 days to  show as delivered, including a weekend.
Remember that 21st century Royal Mail cannot compete with the Victorian era....!
Message 48 of 134
OK thanks. Regarding the returned router, it's not showing at our end yet but I've made a note of the tracking number on our system
Message 49 of 134
Hi Chris,
OK, I'll monitor the connection over the coming few days and get back to you.
Please can you also confirm receipt of the second router that I returned on Friday 24 May using your return packaging/label (it was sent to check if the existing router was the cause of the dropouts, which it wasn't). The Royal Mail tracking number is XE965364596GB and has been shown at 'Home Counties North MC' for over a week now.
Message 50 of 134
OK thanks Chris. Could you see how it goes over the next few days and if the disconnections continue we'll probably need to arrange another engineer visit
Message 51 of 134
Hi Chris,
Since we last spoke on Friday I had 8 dropouts on Friday afternoon/evening and 2 dropouts on Saturday afternoon just before the engineer arrived at ~2pm. He found more corroded connections on the line further away from the property, which he replaced. He also reset the line and put it on a ‘permanent profile’. He left around 3.30pm. Since then I had 2 dropouts on Saturday evening at ~9.30pm and 2 on Sunday morning at ~6 to 7am. I have had no further dropouts since Sunday morning, but that’s only 24 hours and my speeds are much lower than they have been. Since there were 4 dropouts after the engineer visit on Saturday I think there must still be a fault somewhere.
Message 52 of 134
Hi Chris, how did you get on?
Message 53 of 134
Hi Chris,
I've had a text from Openreach so I can see the engineer will visit between 1pm to 6pm tomorrow. Since we last spoke I've had a further 4 VDSL dropouts, so that makes 6 so far since 3pm (~90 mins). I will let you know what the engineer says tomorrow.
Message 54 of 134
Thanks Chris, will that be 'any time from 1PM'? It was with the last Openreach engineer visit.
Message 55 of 134
I've booked the engineer appointment for tomorrow afternoon - June 01 2024, PM - please let us know how you get on
Message 56 of 134
OK, I'll book it for the first available slot (except for the two you've mentioned) - I'll let you know when I've booked it
Message 57 of 134
Anytime apart from tomorrow morning or Sunday afternoon
Message 58 of 134
OK, when can you be available for the engineer visit?
Message 59 of 134
Hi Chris
I've just had another two VDSL dropouts in the past 10-15mins. I think you need to arrange another engineer visit to get this fault fixed.
Message 60 of 134
Hi Chris,
Yes, there was a profile change last night which will be the cause of the disconnection. It's possible that there have been two separate issues, the first one fixed by the engineer and this a separate issue, but as I've said, if the disconnections continue we can arrange another engineer visit
Anonymous User
