on 21-07-2024 08:41 AM
we have been resolving an issue with our router. ( the engineer from BT has asked for a new one)The engineer from BT has also suggested as we have such thick walls in our cottage that we ask you guys if we can get a Fast Booster for the router to set up as a "mesh"system , or ask Talktalk if they can send a mesh system. Is it possible we could try this. We are unable to use PowerPoint sockets as our electrical system is not compatible with using this. We have spent many hours trying but our electrician cannot get solve this either. We have a Sagemcom 5364 router. Would be very grateful for help.Thank you
on 24-07-2024 07:42 AM
I've ordered you a replacement router, please allow 24-48hrs for this to arrive.
Let us know how the connection compares with the replacement router.
on 23-07-2024 10:20 PM
It seems that the customer is having router issues, please can this be replaced?
on 22-07-2024 07:37 AM
Thanks @KeithFrench
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue. Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others. If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc. one of the TalkTalk team will jump in and help out.
on 21-07-2024 09:55 PM
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
on 21-07-2024 09:17 PM
Keith. Thank you. That would be great. We have worked together before. Grateful for your help.
on 21-07-2024 01:44 PM
Before considering any boosters, WiFi interference needs to be checked.
