on 10-01-2022 10:19 AM
Recently WhatsApp calls have stopped working on my home Wi-Fi they work fine on my mobile data and on other Wi-Fi connections just not on my home Wi-Fi anymore.
Any ideas what might be causing this? I was recently moved to a new deal with TalkTalk was there a change to line that has stopped this from working or does the router need updating/changed?
on 11-01-2022 03:34 PM
Glad the 30 minute power down helped.
on 11-01-2022 03:30 PM
WhatsApp calls are now working again after powering off the router for 30 min
Thanks for your help
on 11-01-2022 12:22 PM
Hi Duncan
Thanks for confirming.
Is it still the same following the 30 minute power down?
on 11-01-2022 12:20 PM
Hi Debbie
Nothing under HomeSafe/KidsSafe is turned on
Duncan
on 11-01-2022 12:15 PM
Hi DHB70
Could you also log into My Account and check to see if HomeSafe/KidsSafe has been switched on?
on 11-01-2022 12:12 PM
Yes, it is a Sagemcom WIFI hub, I haven't tried powering down the router for a full 30 minutes but will do that now and see if it helps.
I have checked settings in WhatsApp and checked for updates but this did not help, video and voice calls work fine on the app when using someone else's Wi-Fi or my mobile data so I don't think this issues is with WhatsApp
11-01-2022 08:50 AM - edited 12-01-2022 04:12 AM
You should check the setting of WhatsApp and check for the update of WhatsApp or you should reboot your device if still you have problems than you should go for router.
on 11-01-2022 07:05 AM
Hi DHB70
Are you using the Sagemcom WIFI hub?
Have you tried powering down the router for a full 30 minutes?
on 11-01-2022 06:41 AM
Hi Debbie
I have updated my profile.
on 10-01-2022 10:24 AM
Hi DHB70
Please can you update your Community Profile to include your name and TalkTalk landline number.
