Wi-fi connection to mobile phone.
johand
Message 7 of 7
I have desk top computer, laptop and android mobile phone. Recently mobile phone is unable to receive wi-fi signal outside my home. When doing a connection check I was told that signal to desk top computer fine but to laptop & mobile phone signal was intermittent. Recommendation was to disconnect one of the items.
All 3 have connected perfectly well up until a few weeks ago. What is happening to my wi-fi signal?
6 REPLIES 6
Message 1 of 7
Hi johand,
Thanks for trying that. I think it's unlikely that the wifi part of the router is failing but it could be a software issue so could you try resetting the router to factory default settings, this should resolve any software issues
Restore your router to factory settings - TalkTalk Help & Support
Message 2 of 7
Hi Chris, tried your suggestion of switching off router for 30 mins, switching back on & rebooting phone but sadly had no effect on the problem.
I emailed the computer co. who set up my desktop computer and he said that if 2 of the three devices are struggling with Wi-Fi, it is mre likley that they have something in common that share the same problem - that is, the router. Could be that the Wi-Fi part of the router could be failing.
Info on back of router is FAST5364-3TB S/N N7190804N013031. Are you able to check wi-fi part of the router or do I need new router@
Josie Hand
Message 3 of 7
Hi johand
Just a couple of things to try. Could you switch your router off for 30 minutes then switch back on. Could you also reboot your mobile phone. Once you've done this could you retest and let us know if you are still experiencing the problem
Message 4 of 7
Hi Michelle, not only can I not get wifi connection to my mobile phone outside my home but now cannot receive verification codes to my mobile when trying to make payments via my desktop computer in my home. Really need someone to sort out these issues please.
Message 5 of 7
I'm sorry to hear this. Would you like us to try switching the wifi optimisation off to see how the wireless connection compares?
Divsec
Message 6 of 7
Hi @johand could you clarify where in relation to your home you are when the WiFi signal fails to connect to your phone? Are you in the garden, the town centre or a different County? Regardless of my poor attempts at wit your post has been escalated and you should hear soon.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
