Wifi Calling not working
dannyw13
Chat Champion
Message 62 of 62
Hi All
any chance someone can check my router, cant get wifi calling to enable on any phone in the house, i have seen it could be a simple setting in the router that needs changing
Thanks in advance
Dan
Daniel Waller
61 REPLIES 61
Message 21 of 62
Hi Dan @dannyw13
I'm really sorry to be a pain. Our Devices Team have asked if they can do one more test.
They have asked if you can toggle to flight mode on your device and then try WIFI calling again today? (and let us know if the same issue still happens, date and time) Please ensure you are connected to the WIFI extender at this time too.
Message 23 of 62
Brilliant thanks Debbie 😊
Daniel Waller
Message 24 of 62
Message 25 of 62
Will this be v2 extender?
Dan
Daniel Waller
Message 26 of 62
Thanks Dan @dannyw13
The replacement is on its way now, please allow 48hrs for this to arrive.
There should also be a returns bag for your current extender too. Please let me know how you get on.
Thanks again.
Message 27 of 62
Morning Debbie
That would be great, do you need me to send the existing one back?
Dan
Daniel Waller
Message 28 of 62
Morning Dan @dannyw13
Our Devices Manager has advised that they have been unable to replicate this fault in their labs using the same equipment.
Would you like me to send replacement WIFI extenders so we can rule out a fault with your current one?
Message 29 of 62
Morning Debbie
SSID from the booster is identical to the main router used WPS to link them
WiFi calling appears when downstairs and wifi connected to the router, only when I go upstairs and my phone is connected to the booster it will disappear
Tested a wifi call yesterday and worked OK (downstairs connected to router)
Dan
Daniel Waller
Message 30 of 62
@dannyw13 I think the team are just trying to get a better understanding of your current set up.
Message 31 of 62
Morning @dannyw13
Some more questions from our Devices Team:
Have you have changed the SSID's on the router?
If they are running extenders, could they remove the extenders and just use the Hub with v1 and attempt a Wi-Fi Call?
Message 32 of 62
Thanks Debbie
Daniel Waller
Message 33 of 62
Message 34 of 62
Hi Debbie
For me I can tell by wifi 6 connection on the booster, the main talktalk router does not have wifi 6, you can change the wifi name for the extender also to distinguish which is what
Dan
Daniel Waller
Message 35 of 62
Hi @dannyw13
The Devices Team are trying to replicate this fault in the labs.
Question from the team - how does the customer know their device is connected to the Wi-Fi booster at the time of making Wi-Fi call?
Message 36 of 62
Thanks @dannyw13
I've sent all this information over to our Devices Manager and I will let you know as soon as they come back to me.
Message 37 of 62
Using a Galaxy Z Fold 3, wifi calling works at other locations just not at home here
Dan
Daniel Waller
Message 38 of 62
Hi Debbie
PM sent with serial number
Dan
Daniel Waller
Message 39 of 62
Hi @dannyw13
Can you also confirm which mobile device you are using? (make and model)
Message 40 of 62
Hi @dannyw13
Please can you send me a Private Message with the serial number from the WIFI extender?
