Wifi Calling not working
dannyw13
Chat Champion
Message 62 of 62
Hi All
any chance someone can check my router, cant get wifi calling to enable on any phone in the house, i have seen it could be a simple setting in the router that needs changing
Thanks in advance
Dan
Daniel Waller
61 REPLIES 61
Message 41 of 62
Thanks @KeithFrench
I've received your message and I've passed this onto the Devices Team to get some answers.
Message 42 of 62
Hi @Debbie-TalkTalk
Thanks very much. I have just sent you a PM about this.
Message 43 of 62
Thanks @KeithFrench
I'm still waiting for a date for when this firmware will be released.
As soon as I have more information then I will let you know.
Message 44 of 62
Hi @dannyw13
The problem is that there is a disconnect between the router & the V1 266 due to incorrect firmware on the version 1. I have been waiting for some time to find out when the new firmware will be updated on them. I am currently using a V2 266, which works for WiFi calling no problem.
I will chase Talktalk up again, @Debbie-TalkTalk has been liaising with their Devices team to get me an answer.
Message 45 of 62
Hi Keith
Yes it's v1,
3 lights on front of the extender
Thanks for the help
Dan
Daniel Waller
Message 46 of 62
No @dannyw13 the router will be on V206, which is new, the F266's firmware will be totally different.
Thanks for the screenshot. Is that the whole page? There should be 266 information displayed below the router's in that sub tab unless you are on Version 1 of the 266.
I keep asking, please can you confirm which version of 266 you have, this is vital to me being able to deal with your problem.
Message 47 of 62
Hi Keith
will pm you
Can see the extender is on SG4K100206, so a prior version
Dan
Daniel Waller
Message 48 of 62
The most crucial thing is are you on the Version 1 266 (three lights on the front) or the version 2 (one light underneath).
You can log into it, you use the router's UI go to:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 5Ghz gear icon >
Wi-Fi Mesh
In there get me a screenshot of the Extenders sub tab (PM this to me to preserve your privacy).
Message 49 of 62
Hi Keith
Router version SG4K100206
With the extender what is the default gateway to login is it the same as the router?, is have to connect seperately to find out but I assume it will be original firmware
Daniel Waller
Message 50 of 62
Thanks @KeithFrench
Michelle 🙂
Message 51 of 62
Just retested this when connected to my V2 F266 & it worked fine. Which router firmware & F266 version are you using?
Message 52 of 62
Hi Keith
It's a sagecom fast266
Dan
Daniel Waller
Message 53 of 62
Hi @dannyw13
@Anonymous has asked me to help you with this. Which make/model of extender are you using?
Message 54 of 62
Good morning,
@KeithFrench  have you come across this before?
Message 55 of 62
Hi Chris
Works in main router wifi, but when on the talktalk wifi extender upstairs it doesn't work, does the wifi extender setting also need changing?
Dan
Daniel Waller
Message 56 of 62
Yes, the change has gone through. When it convenient could you switch the router off and leave it off for at least 30 minutes then switch back on and retest. Please let us know how you get on
Message 57 of 62
Thanks Chris, has it been done? Wifi calling still not showing up
It is definitely enabled in my home settings
Dan
Daniel Waller
Message 58 of 62
OK, I'll do this, please don't switch off your router
Message 59 of 62
Thanks for coming back Chris, yes please proceed 🙂
Daniel Waller
Chris-TalkTalk
Message 60 of 62
Hi dannyw13,
I can make a change that will hopefully fix the problem, is it OK to do it now, your internet connection will be down for a few minutes?
