on 07-11-2024 07:34 PM
Hi All
any chance someone can check my router, cant get wifi calling to enable on any phone in the house, i have seen it could be a simple setting in the router that needs changing
Thanks in advance
Dan
on 17-03-2025 12:25 PM
If you start your own thread (new message), we’d love to help.
We’ve found that posting in someone else’s conversation makes it harder to follow when looking for an answer.
It’s easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
on 17-03-2025 11:55 AM
Can you help, my WiFi is not working again.
on 08-01-2025 06:56 AM
Most phones will use mobile data as the primary connection and Wi-Fi as the fallback.
For android there are useful apps such as macrodroid that I find helpful. These can be set to perform functions such as turning off data when connected to your Wi-Fi , and turning it on when not connected etc.
on 22-11-2024 09:33 AM
Hi Dan
You're welcome 🙂
If you do experience any further issues then please let me know.
I've sent you a Private Message with a link to a short survey for the Community.
Thanks again.
on 22-11-2024 09:31 AM
Morning
That's ok, yes all good
Thanks for all The support 😊
Dan
on 22-11-2024 09:30 AM
Morning Dan
Really sorry, I didn't see your last reply.
I'm glad it's arrived and everything has connected up ok 🙂
on 22-11-2024 09:21 AM
Hey Debbie
Yeah did you see my previous post? 😊
on 22-11-2024 07:20 AM
Hi Dan
Has the replacement extender arrived?
on 20-11-2024 10:20 PM
Hey Debbie
V2 booster now online and showing up in the router as Keith said
Wifi calling does work when mobile data is off, must be firmware of the phone preferring mobile data over wifi which is fine, no option to change preferred anymore on android 14 unless carrier specific
Thanks for the support 😊
on 19-11-2024 06:53 AM
Thanks Dan 🙂
on 18-11-2024 03:41 PM
Sure thing, will keep you updated
on 18-11-2024 02:20 PM
Thanks Dan @dannyw13
It may still be worth testing with the new extender I've sent just to see how it compares.
on 18-11-2024 02:18 PM
Thanks Keith, makes sense
I guess that makes sense, thanks for looking into this
18-11-2024 01:44 PM - edited 18-11-2024 01:44 PM
One of my team has checked some settings on their Samsung handset for WIFI calling.
By default, phones will use mobile data for calling and only use Wi-Fi calling if the mobile signal is weak or lost. This can usually be changed in the settings.....
Tap Wi-Fi Calling, then choose your preferences:
Mobile network preferred: Your mobile network will be used for calls. If your network is unavailable, Wi-Fi will be used.
Wi-Fi preferred: Your phone's Wi-Fi network will be used for calls. If Wi-Fi is unavailable, the mobile network will be used.
on 18-11-2024 01:43 PM
In my testing @dannyw13 @Debbie-TalkTalk if this is an Android, you have to set the priority for WiFi calling to:-
I would guess that iPhones would be very similar.
on 18-11-2024 01:36 PM
Ahh ok, just checked with the team and they said the signal for the extender appears to be strong but the phone may be connecting to phone data when upstairs instead of the WIFI extender. Switching into airplane mode makes it connect to the extender.
on 18-11-2024 01:27 PM
Hi Debbie
Seems wifi calling has now appeared upstairs on the extender, in airplane mode, as soon as I turn it off wifi calling disappears
on 18-11-2024 12:53 PM
on 18-11-2024 12:03 PM
No pain at all
1st screenshot is on the extender
2nd screenshot is downstairs connected to the router directly
