on 29-01-2022 11:02 AM
For the past few months i've been having internet issues but only over wifi.
Its quite random when it happens and I only knew about it as I leave an echo on for the dog and when I got home it was off.
Over xmas and being at home I noticed it and found that even though the internet over wifi was off I could screen share over wifi from my laptop to my mac mini which is hard wired to the router and the internet was working.
Eventually it will come back on but its quite annoying.
I've been through all starts and reboots and moved the router and changed channels.
on 06-02-2022 03:06 PM
Hi, Think I've added the number.
on 31-01-2022 07:37 AM
Hi dbeevers
Please can you add your TalkTalk landline number to your Community Profile, we can then look into this further.
on 29-01-2022 01:14 PM
If it is only over WiFi that the problem exists, it might be WiFi interference. Changing channels without investigating the state of them can make things worse. The problem is possibly only affecting one band with the laptop working over the other.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
