Will TalkTalk contact my old supplier and help cancel my contact
Nelson527
Message 3 of 3
Will TalkTalk contact my old supplier and help cancel my contract
Arne-TalkTalk
Message 1 of 3
Hi @Nelson527
I can see an inflight order to transfer to us, but I would always recommend contacting your current supplier to check that they have received a request from us.
Gliwmaeden2
Message 2 of 3
It depends whether your old supplier is using the One Touch switch scheme etc, @Nelson527.
Have you asked Talktalk to take over the same phone number?
If it's a mainstream (Openreach) ADSL or FTTC service, then it should be straightforward too.
But usually checking that the old supplier knows you are leaving is advisable! You should really be checking that company's cancellation guidelines.
Anonymous User
