You View box
Pecospete
Message 3 of 3
You View bow not working when I changed to a new IG smart television
Message 1 of 3
What model of TV box do you have, and are you connecting via HDMI etc ?
Message 2 of 3
Have you added it as a device using the device connected settings?
The box should work, as I have mine working with an LG TV.
Or are you saying the box has failed totally?
Double check the connections and also try, if possible a different HDMI cable.
Hope this helps
