firmware update wifi hub
on 20-10-2023 06:16 PM
Message 8 of 8
I think my router needs a firmware update as its still on v1.05t and its constantly recently restarting on its own with no clear reason as to why, i have tried restarting it to no avail. Ive unplugged it and plugged it back in yet it keeps restarting on its own and ive ran a service check and says that there is no issue and my connection is fine. I cant really pinpoint a reason as to why this could be happening but i think upgrading the firmware could be a good try.
Labels:
- Labels:
Buffering
Connection
Firmware
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
7 REPLIES 7
on 25-10-2023 10:19 AM
Message 1 of 8
Hi zephyrX1
Do you still need help with this?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 23-10-2023 07:17 AM
Message 2 of 8
Hi zephyrX1
Please can you add your TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 22-10-2023 01:03 PM
Message 3 of 8
It could also be that the connection is unstable, which would give the same light sequence. Please can you try moving the router and if needs be a phone to the test socket behind the master socket's removable faceplate (if you have that design). Then connect them to it via a new or known good microfilter? Let me know the results.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-10-2023 06:39 PM
Message 4 of 8
I’m pretty confident it’s restarting on its own, it will completely cut not slow down or anything it just cuts then the light is flashing orange as soon as it cuts and eventually goes back to solid white. I play games so I’m using Ethernet and it affects this too and I am not restarting it myself as i am usually in the middle of a game whenever this happens so I literally physically cannot restart it with my body I’ve narrowed it down to most likely being due to the fact there’s an open part infront of my house which has internet cables in it; I’m assuming it was being worked on and left but it’s been left open for weeks and due to the recent heavy rain it might be affecting the internet to my house
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-10-2023 03:18 PM
Message 5 of 8
OK, let's take this back a step:-
- Is it really restarting on its own then (there should be entries in the log) & how do you know that it is? What does the light do at this time?
- Alternatively, is your internet connection just slowing up and you restarting the router itself brings things back to life?
- If the latter is the case, does it only affect Wi-Fi connected devices or Ethernet (if you have any) ones as wel?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-10-2023 01:40 PM
Message 6 of 8
Ive checked that and im not even seeing anything whenever it restarts, it doesnt even pop up in the user logs or the debug logs. All it shows is whenever ive restarted it however i can clearly see it restarting itself as the light goes orange and then proceeds to flash white and orange then white solid when it goes back on. Im assuming this means it is restarting itself
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-10-2023 09:57 PM
Message 7 of 8
If you look in the user log are there entries along the lines of:-
kernel panic
If so, it needs upgrading to V1.06.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- Logs missing on Router. in Fibre
- WiFi hub version v1.05t in Broadband
- TalkTalk email saying my router is no longer supported with software and security updates in Broadband
- Fibre 65 lagging, discconections, slowing down, throttling? in Broadband
- Regular drop outs (since SG4K100208 Firmware upgrade) in Fibre
