on 02-04-2023 07:46 PM
Hello.
I have a contract for a Fiber35 package. The download speed is about 27 Mbps and the upload speed is about 6 Mbps. On February 23, the speed suddenly dropped to about 13 Mbps to the router and 11 Mbps to the PC. A line check showed a problem. On March 2, an engineer arrived. After his visit, the speeds did not change much and the line test continued to show the problem. After about three weeks, the line test shows that everything is fine, but the speeds to the router are 18 Mbps and to the computer 15 to 16 Mbps. This situation continues to this day. I don't understand why the speeds can't go back to normal as they were according to the subscription, and it's been over a month! My neighbor has Internet on the same network and still has normal speeds and we are connected the same way!! I do not understand! I'm still using the original router and cables I received when I first connected, and why is the speed difference 2 to 3 Mbps? Please explain this problem to me and help me get back to normal.
on 20-05-2024 12:08 AM
Keep the set up exactly as it is until staff respond (during the day), @Lesman.
on 19-05-2024 11:37 PM
on 14-05-2024 12:12 PM
OK thanks. Hopefully DLM will move you to a faster profile over the next couple of days
on 14-05-2024 11:53 AM
Ok. The router will be connected to the test socket for 48 hours.
I now measured the speed - 25 Mbps to the router and 22 Mbps to the computer.
Measurement taken on the TalkTalk website.
The connection is still normal, it does not interrupt, but the Internet works all the time on the old router.
Les
on 14-05-2024 10:19 AM
Could you leave it connected to the test socket for 48 hours and we'll see if the disconnections continue and if DLM moves you to a faster profile. If there's no improvement then we'll probably need to arrange an engineer visit
on 14-05-2024 10:09 AM
Hi Chris
The phone works normally, I don't hear anything strange.
Currently, the router is connected to the test socket through a filter.
The speed has not changed.
How long should I leave the router connected like this?
Les
on 14-05-2024 08:00 AM
Hi Les,
I can see that your connection has been unstable. Line test is picking up a potential issue. Is your router currently connected to your test socket? Are you experiencing any problems with your telephone service?
on 13-05-2024 11:54 PM
Hi Michelle
About three weeks ago, another Internet comedy began. The speed ranged from about 33 Mbps to about 10 Mbps. The internet stopped working and came back on by itself. There were two visits by engineers (after a test on the TalkTalk website - an error was found). After the last visit, the speed was around 28 Mbps and the internet worked normally. Yesterday I started having problems with internet interruptions. About four hours ago, I connected my old router. During all this time, the Internet never stopped working, but the speed dropped to about 23 Mbps - that is, about 10 Mbps as usual. The router that was disconnected worked for about five months, it is not that old.
I don't understand any of this.
What do I do with it?
Please help.
Les
on 13-03-2024 11:06 AM
Morning Les,
That's excellent news 🙂 Please let us know if there is anything else we can help with 🙂
on 13-03-2024 11:04 AM
Hi Michelle
Speed test and other test functions also started working properly.
The "magic wand" worked and everything works fine.👍🌷
Les
on 13-03-2024 06:12 AM
Hi Les,
I'm really glad to hear this and I'm glad to hear that the fault has been resolved and your speeds have improved 🙂 I've chased the My Connection team now about the speed tester issue and I will post back here as soon as they reply with an update.
Michelle 🙂
on 12-03-2024 08:41 PM
Hi Michelle
Two days ago, the replacement of a section of the main line (approximately 25 meters) was completed.
There is good news.
The speed returned to normal - about 33 Mbps. It is now possible to check the speed on the TalkTalk website through my account. My neighbor's internet speed has also increased. So the problem was still in the main line cable. I think so.
I hope that my internet problems that have been going on since April last year are finally over.
Thank you for your help.
Les
on 12-03-2024 10:48 AM
Hi Les,
Just a quick post to let you know that I've not forgotten your thread and we'll re-check first thing in the morning when we should receive another update from Openreach.
on 07-03-2024 07:08 AM
Morning Les,
We've received a further update to advise that further dig work is required to fix a buried joint. We've been advised that the next update is due on 13/03 so we'll check back on this date for a further update for you.
on 04-03-2024 10:15 AM
Hi Les
We will re escalate the speed checker issues once the fault has been resolved,
Thanks again.
on 04-03-2024 10:08 AM
Hi Debbie
Thank you for the information. Currently, the earthworks are being carried out by Openreach. However, I still can't check the speed through my account. I informed about it on February 23.
Les
on 04-03-2024 09:34 AM
Hi Lesman
I've contacted Openreach this morning for an update and they have advised that the engineer will be working on this fault today and further updates will be available on the end of the day.
on 01-03-2024 03:21 PM
Hi Michelle
I will wait patiently for the problem to be resolved.
Regards.
Les
on 01-03-2024 12:27 PM
Hi again,
I've checked again and there are no further updates and we're still awaiting an update on the dig work. If we don't hear anymore by Monday morning then we can contact Openreach for an update for you.
on 01-03-2024 07:19 AM
Morning Les,
No additional updates as yet so I will check again in a few hours.
