vpn not connecting
GraceNixon
Message 8 of 8
I have no VPN connection on my new router with you, I used to on my old router and IT at my company have done everything possible but they can't understand why it won't work. I went to a family members house who has the same router for me and I could get VPN connection
Grace Nixon-Brown
7 REPLIES 7
Message 1 of 8
Hi GraceNixon
Is your VPN connection working ok now?
Message 2 of 8
the new firmware will allow PPTP Protocol to work.
GraceNixon
Message 3 of 8
Hi Karl,
Thanks for this - just spoken to my IT manager at work and he's asked will this allow PPTP passthrough?
Many thanks, Grace
Grace Nixon-Brown
Message 4 of 8
I've updated the router firmware, try the VPN now and see if it works.
Message 5 of 8
Hi Debbie, added this in but here it is also for ease *removed for security*
Grace Nixon-Brown
Message 6 of 8
Hi GraceNixon
Please can you add your TalkTalk landline number to your Community Profile, I can then take a look at this for you.
Message 7 of 8
Which make/model of TalkTalk router do you have (I am guessing a Sagemcom 5364 or 5464) & what firmware version is it running?
