Broadband issues
10 REPLIES 10
My router restarts at least 3 times in a morning (every morning) and when I finally got internet access my speed is bellow 5MB/s I've got "Faster Fiber" but this isn't remotely fast.
Please help
Sincerely a disappointed customer.
Kind regards Al
Hi Juvy13, I can see the Openreach engineer has been out and has rectified the issue, your internet connection should now be stable
Hi my internet speed is back to normal but my connection is far from stable the router has restarted itself around 10 times yesterday. It’s starts with DNS errors than it resets.
Can you please look into this?
Also I would like to talk someone regarding my bill since my speed was less than the 10% of what we agreed for more than a billing period and I’m still having issues.
Stay safe
Kind regards Al
Hi Juvy13
Apologies for the delay.
I've completed a line test which has detected a possible fault so I have passed this back over to Openreach to be investigated by a line engineer.
Openreach are working to fix all faults as quickly as possible.
Hi Juvy13
How has the connection been since your last post?
Hi Debbie
Thanks it's better but still not on full potential (or even close tbf).
The download speed averages around 15megs with a single device connected to it and the upload speed is unbearable average 1MBPS.
J
Kind regards Al
Hi Juvy13,
I'm sorry to hear this and I'm just taking a look now.
I've run a test on the line which has detected a possible line fault so I've passed this over to Openreach for an external line investigation to be completed. If you don't hear anymore by Monday then please post back here and we can re-check for an update on the fault for you.
This is going to be third Openreach engineer since the first error. Is there anything else we can do here to solve the issue since it’s didn’t worked for the first two attempts I don’t think that the 3rd time would make any difference.
Thanks for your answer
Have a nice weekend
Kind regards Al
Hi Juvy13
Openreach have left notes to advise that this fault has been cleared.
Has the fault been resolved?
Hi Debbie
It's pretty much the same as the past two times:
the connection was fine for a few days and now it is significantly reduced, and the router keeps randomly rejecting my devices and/or gives the flashing amber error.
Kind regards Al
Hi Juvy13
Apologies for this.
I've completed a line test which is detecting a fault so I have escalated this back over to Openreach to be investigated by a line engineer.
