Firmware Update
11 REPLIES 11
Hi there,
Could I please request a firmware update? Looks like I'm still stuck on SG4K10001400t.
Thanks!
Alex
Hi Alex
Thanks for creating a thread 🙂
I'm unable to connect to your router. Please can you factory reset the router using the pin hole reset for ten seconds? I can then try this again.
Sorry for the delay Debbie. I've just done this - any better now?
Alex
Hi Alex
I'm still unable to connect, apologies for this. Did you factory reset the router using the pin hole reset for a full ten seconds?
I did and just completed it again for good measure. Are there any other options?
Hi Alex
Is TR069 enabled in the router settings?
Comparing to some other screenshots on the forum, I don't have a TR69 page here?
Hi Alex,
Still unable to communicate with your router. I can send out a replacement, would you like me to arrange this?
Yes please Chris - thank you.
I've ordered the router, should be with your within a couple of days but please allow up to 5 working days for delivery
Thanks Chris - much appreciated!
