I was wondering if you can push firmware version v1.10t to my HG635 router as the trials seem to have been a success.
Neil Munford
Hi Neil
OCE's emailed with your request.
Remote management on?
Just leave the router powered and connected to the line and it should get updated tomorrow.
Hi Neil
I'll update the firmware now 🙂
Hi Karl,
My router rebooted just after midday today and my firmware is upto v1.10t now.
Thanks for doing that for me.
One thing I have noticed is my Fibre BB is now syncing at 15Mb where before the upgrade it synced at 3-4Mb, maybe just the function of a reboot has kicked it into life.
I will keep an eye on it and see what else falls out the tree.
Thanks again.
Neil Munford
Thanks for letting me know. Keep an eye on things and report back if there are any problems.
Like Neil, I'd like my HG635 Router Firmware updated from its present v1.06t to the latest v1.10 please.
My router has remote management enabled.
Can you kindly push the firmware to my router so it will update please?
Carl
Carl
Hi Carl
I've updated your router firmware as requested.
Hi CarlL,
How have you found the connection since the firmware update?
can you please update my router to the lastest version please getting the odd internet dropout and struggling to connect to network. also the internet speed drops to a point where it will not load any webpages.
Hi, Is there any chance of pushing the new firmware to my router please 1.10,many thanks in advance.
Hi could I get this firmware update please, thanks in advance
I have just discoverd this thread. My Hg635 router is on version 1.01, presumably the origianal.Remote magagement is on but no formware updates have ever taken place I assume. If th erouter is working Ok is there any point in this and if so how do I perform the update. The router is quite aged now and i was wondering if this would improve performannce. Thanks
It's an old thread so not on the OCE radar.
The original firmware /software version for the HG635 was v1.04t. The current firmware / software version is v1.06t. There was a trial of v1.10t but all existing HG635 routers are awaiting the release of new firmware.
To find out what your router software version is:
I am not sure but I believe v1.14 has been released for this router
If I am correct then your router should update itself shortly
It may be different if your line is a business line
Bill
It’s been on the same version for a long time now that’s the reason I was asking for a push update from TalkTalk.
