Router and connecting to work VPN
4 REPLIES 4
Nbiddiscombe
Hello
i was having some issues connecting a work laptop to the WiFi and having issues with the VPN. They said they had a DSL-3782 D-link router and had the same issue and were sent a HG633 which solved the problem.
My router looks like it’s a H635 - would a different router solve this issue or do I need to look into why else I’m having VPN issues?
thanks
nick
Divsec
Hi Nick the Hg 635 is A very adequate router, have you tried resetting etc.?
I have flagged your post for assistance and you should hear during tomorrow. In the meantime please check your community profile and add your phone number if necessary.
Hi Nbiddiscombe,
The HG635 router should work fine with VPN. Have you tried factory resetting the router and then retesting this again?
Nbiddiscombe
I have done a factory reset and that seemed to solve the problem. Thanks!
Hi Nbiddiscombe
