Router problems
7 REPLIES 7
simongrist59
My router seems to have developed a problem with the wifi. You can connect and work using a device that support 5GHz but any device that only supports 2.4GHz cannot connect. I have tried rebooting and that did not fix it. Using a wifi  analyzer on android I can see there are frequent periods when the signal drop to zero. Any suggestion or do I need a new router?
Hi simongrist59
Which router are you using? (make and model)
simongrist59
Hi Debbie,
   Huawei HG633.
Simon
Hi simongrist59
Have you also factory reset the router using the pin hole reset for ten seconds?
I can send a replacement router for testing if you would like me to arrange this?
simongrist59
Hi Debbie,
    Please can you send a replacement router for testing.
Thank you,
Simon
Hi Simon
simongrist59
The new router is working well.  I well send the old one back.
Thanks,
Simon
Hi Simon
That's great, thanks for keeping us updated 🙂
