Broadband dropout & speed reduction
SoF00
Message 31 of 31
Hi - We have been having short (2 - 3 minute) broadband interruptions for a while now and the internet speed is also below the guaranteed level although still usable.  Connection test says there could be a line fault but line test says unable to identify a fault on the line.
30 REPLIES 30
Message 1 of 31
Thanks for confirming that speeds have increased.
SoF00
Message 2 of 31
Ok - left Router off for nearly an hour, now speed back up to over 40Mbs.  Thanks for that.
Anonymous User
Message 3 of 31
Hi again,
Ok thanks for confirming. Could you try powering down the router for a full 30 minutes and then retest the speeds again please as this will reset the current session and can often increase the throughput speeds.
SoF00
Message 4 of 31
Hi Michelle, we're getting around 30Mbs which is still very usable but not the 40+ we used to get.
Anonymous User
Message 5 of 31
Thanks for the update. What speeds are you currently seeing at the moment please?
SoF00
Message 6 of 31
Hi - Openreach repaired the line yesterday but the broadband speed is still below guaranteed minimum. Does something else need to be done?
Message 7 of 31
SoF00
Message 8 of 31
Thanks for that
Message 9 of 31
I've booked the appointment for tomorrow afternoon - January 09 2024, PM - please let us know how you get on
SoF00
Message 10 of 31
Preferably the pm slot but am ok
SoF00
Message 11 of 31
That would be good if possible
Message 12 of 31
Do you just want me to book the first available appointment, we can usually get next working day or the working day after?
SoF00
Message 13 of 31
Yes I accept potential charges and can provide availability weekday 8-18hrs (by prior agreement only)
Message 14 of 31
At this stage we will need to arrange an engineer visit to investigate further. If you'd like us to arrange the engineer can you confirm:
SoF00
Message 15 of 31
Is this definitely an issue at my end requiring an engineer?  Odds are its the last bit off copper to the house.
If an engineer visit is required then yes please arrange.
Message 16 of 31
OK, thanks for testing. Would you like us to arrange an engineer visit? If you would then we'll confirm some details with you
SoF00
Message 17 of 31
Morning, 6 broadband dropout and 3 minute recovers over the weekend.  Internet speed still only 33Mbps, guaranteed is 39Mbps and I used to get over 40Mbps so there is still a problem.
Message 18 of 31
Message 19 of 31
Ok thanks, I'll keep an eye on it. Thanks for your help
Message 20 of 31
OK thanks. Could you monitor the connection over the weekend to see if there's any improvement. If there isn't then the next step will be to arrange an engineer visit to your home
Anonymous User
