Broadband not working
jamespb407
Message 17 of 17
My broadband has been down since last night.
16 REPLIES 16
Message 1 of 17
Hi @jamespb407
Fault reported Friday19th resolved Wed 23rd, Auto Compensation is applicable for 1 day.
Your cancellation fee is over £200 that would not be waived.
Message 2 of 17
I'd post afresh in the billing section but with reference to this thread, @jamespb407.
If it wasn't a line fault (just a router) they may quibble as it won't necessarily show on their records.
And it won't be for a huge amount of time as the first few days are allowed for resolving the fault.
Details of how automatic compensation works:
https://community.talktalk.co.uk/t5/Articles/About-your-auto-compensation-credit/ta-p/2326583
Message 3 of 17
Message 4 of 17
are you able to advise on the status of compensation for this previous outage? It has been 28 days and I have received nothing from Talktalk on the compensation I am due, and have previously asked for my exit fee to be waived as a result of this outage and told to await compensation
Message 5 of 17
Hi james,
I'm glad to hear this 🙂
Message 6 of 17
Good morning
The replacement router has arrived and the connection has been restored.
I will send back the old model tomorrow.
Message 7 of 17
Morning james,
Ok thank you for the update.
Message 8 of 17
No. I understand it was ordered Saturday and so hopefully tomorrow it will arrive
Message 9 of 17
Did the router arrive today ?
Message 10 of 17
Hi james,
Thanks for the update. Yes please and we'll check back in with you later on this afternoon to see how you're getting on.
Message 11 of 17
I am receiving a replacement router today to test if that is the problem. Should I start that up as normal when it arrives?
Message 12 of 17
I'm really sorry for the delay. I've run a test on the line which is clear but the line is not showing in sync. Does your main socket have a test socket please? Do you also have an alternative router that you can test with? If not then we can send a replacement router for testing purposes to rule this out.
Message 13 of 17
Hi @jamespb407
Apologies for the delay. We are still experiencing some system issues at the moment affecting line tests.
I will post back to confirm once this has been resolved so we can run some tests.
Message 14 of 17
I have done this
jamespb407
Message 15 of 17
I have added my number
Message 16 of 17
Hi @jamespb407
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
