on 19-04-2023 11:52 AM
Help! My broadband/fiber router has stopped working I have tried the help pages to no avail. The light was flashing Amber but after the 20 minute power down it is now steady Amber but still no Internet can anyone help me resolve this?
02-05-2023 01:50 PM - edited 02-05-2023 01:52 PM
Hi Edd24
My apologies, I misunderstood. If you would prefer to keep using the old router this will be fine.
Please can you return the new router using the returns bag.
on 02-05-2023 01:44 PM
I didn't change box as fault stopped do I need to swap or can I send new one back just a fax setting up all devices.
on 02-05-2023 12:57 PM
Hi Edd24
If the new router has resolved the fault then please can you return the old router using the pre paid returns bag (within the next couple of weeks)
Thanks again.
on 02-05-2023 12:53 PM
Sorry for delay I have been on holiday. My new box has arrived and my BB has settled down do I need to swap boxes also do I need to return old one before certain date?
on 19-04-2023 01:44 PM
HI Edd
Do any lights change on the Openreach modem?
on 19-04-2023 01:41 PM
Yes it is on a side board not in a cupboard or anything.
on 19-04-2023 01:13 PM
Hi Edd
Is the router kept in a well ventilated space? The router should not stop working after such a short time.
I have linked to our help page too.
on 19-04-2023 01:12 PM
Can you please send the link for compensation.
on 19-04-2023 01:11 PM
I have had a total of three routers up to now so will be on my forth the other issues were previous years.
on 19-04-2023 01:10 PM
Yes
on 19-04-2023 12:51 PM
@Edd24, so the current faulty router is the one that is only a couple of months old?
Previous issue in February, this year, @Debbie-TalkTalk.
@Edd24 the compensation link was sent out to you in your thread in February. It covers total loss of service, but can't be calculated till after the issue is resolved. It is a generous amount per day to cover your extra costs of using data etc and the inconvenience.
on 19-04-2023 12:42 PM
Hi Edd
When did you last replace the router? Was this only recently?
If the same fault is still present with the replacement router then the next step will be an Openreach engineer visit to the property.
on 19-04-2023 12:39 PM
No change. It just stopped working this morning! Is there nothing I can do to fix it while I wait plus will I be compensated as I need my Internet for work and for my family and I have had this happen 3 times now where I have had to install a new router and be without Internet while waiting to resolve all the faults I have had since being a customer of talk talks!
on 19-04-2023 12:06 PM
Hi Edd
Has anything changed with your set up since the installation?
on 19-04-2023 12:02 PM
I suppose so but what do I do in the meantime this isn't the first time this has happened I can't keep putting up with talk talks poor service.
on 19-04-2023 11:56 AM
Hi Edd24
The line tests are clear. Are you happy for me to send a replacement router for testing?
