Broadband
Alexandria1
Message 3 of 3
Hi I'm having the old router and is not good enough and cutting off recently.. how can I upgrade to eero?
Message 1 of 3
Hi @Alexandria1
Eeros are only available on certain packages.
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
Message 2 of 3
It depends on your contract. Even on upgrades to contracts an Eero may not be available.
If your router is faulty it will likely be replaced with a similar one.
If you can describe your issues and what you have done to try and rectify the issue (such as resetting it) staff will look into this further on their return after the weekend.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
