on 16-09-2024 09:08 PM
As per multiple over posts in the past few days, I am also having the same issue with AnyConnect - was working Friday 13th, not working today Monday 16th
Cannot connect to company Cisco AnyConnect vpn - TalkTalk Help & Support
Cisco anyconnect stopped working today - TalkTalk Help & Support
Connecting to company VPN - TalkTalk Help & Support
WiFi Hub Router firmware is SG4K100202
Works via mobile hotspot
Exactly the same problem as @kasakaa
@Karl-TalkTalk @Debbie-TalkTalk
Answered! Go to Solution.
on 30-09-2024 11:47 AM
on 30-09-2024 11:46 AM
No because tomorrow will be the first time using the VPN after restating this router over a long time. Which routers versions the issue affecting?
Thanks and sorry for asking but I see nowhere saying this has been resolved.
on 30-09-2024 11:39 AM
Hi @compu
Apologies for the confusion, are you currently experiencing an issue when you're using your VPN?
on 30-09-2024 11:36 AM
Hi, what is the solution on this? I also need to use Cisco AnyConnect tomorrow.
I am currently still on version 100174 but is the issue is caused by the latest version please do not update my router as otherwise I am going to have to remove the router again.
on 27-09-2024 10:04 AM
on 25-09-2024 11:39 AM
on 25-09-2024 11:31 AM
I am currently having this issue, “could not connect to server, please verify internet connectivity and server address” every other device in my house is online
on 25-09-2024 07:39 AM
on 24-09-2024 07:41 PM
Please start your own topic and the support team can help.
on 24-09-2024 07:34 PM
Can this firmware update be added for me too please? Exact same issue and I am not being paid while I cannot connect! Thank you
on 24-09-2024 09:40 AM
on 24-09-2024 09:35 AM
Hi @Anonymous
VPN Protocol: IKEv2/IPsec NAT-T
Cisco Any connect Secure Mobility Client version 4.10.08025
on 24-09-2024 09:23 AM
Hi @jono3000
Our Devices Team have asked if you are able to confirm your VPN Protocol/SW Version, as this will help our Devices Team with their investigations?
on 20-09-2024 06:39 AM
Hi @pelf619
I'm sorry to hear this. As advised, please can you create your own topic and we can look into this further for you.
on 19-09-2024 07:47 PM
@pelf619 if you create a new topic the support team will take a look. Once they picked up my issue they had it fixed in minutes. They didn't say what they did but I think it was a router firmware update.
on 19-09-2024 04:26 PM
I am also having the same issue. Can you publish the resolution please so that other people can get this fixed
on 19-09-2024 10:05 AM
Hi @Woody_
Apologies for this.
Please can you create a new topic and I will take a look at this for you.
on 19-09-2024 09:54 AM
I'm also having this issue. I spent an hour on the TT support chat yesterday and they turned off my HomeSafe but that hasn't made any difference. If the solution is something that I can change myself please can someone post what that is? If the fix requires TT support please can someone contact me asap??? Thanks.
on 19-09-2024 08:51 AM
Hi I’ve just created a new post about it. Thanks
https://community.talktalk.co.uk/t5/Full-Fibre/CISCO-ANYCONNECT-VPN-NO-LONGER-WORKING/m-p/3064991
