Eero 6 Amazon Fire Stick 5GHz issue
JoeBullen
Message 46 of 46
Hi there,
Has anyone found a fix for getting your Amazon Fire Stick to connect to the 5GHz connection instead of the 2.4GHz connection?
Kind regards,
Joe
45 REPLIES 45
Message 21 of 46
Hi @JoeBullen
I would think that it is highly likely that the Firestick will not support the 5GHz band when the Eero is using channel 155.
Message 22 of 46
Thanks for your help Michelle
I’m desperate to get this sorted out this week before I decide what to do moving forwards
Message 23 of 46
Hi Joe,
I've asked the team if this may be related to the channel 155 issue that you've mentioned on your other topic and I'll keep you posted.
Message 24 of 46
Thanks Michelle.
Message 25 of 46
Hi Joe,
I'm really sorry for the delay. I've chased this for an update now.
Message 26 of 46
Hi @JoeBullen
The poor WiFi reception is something that I can help a lot with. However, to save confusion, could you start a new thread for that, as it could get confusing using one thread for two different problems? Please @mention me into the new thread.
Message 27 of 46
Hi Michelle,
Have you had any updates yet?
The other issue I am having since I have updated my internet connection and started using this new router is the amount of areas in my house where I lose internet connection.
I never had this issue with my previous connection/router
Message 28 of 46
Hi Joe,
I'll post back as soon as I know more.
Message 29 of 46
Your problem is rather different to the one in that video. The only way to resolve it is via the fix from Eero that @Anonymous has requested for you.
Message 30 of 46
Ah brilliant. That is great news.
I just tried this but unfortunately it did not work
https://youtu.be/RoOFmxoo57g?si=CoJkzmasiueG4RXx
Message 31 of 46
Yes, once the fix is applied you should be OK.
Message 32 of 46
Ah ok
and will this help connect my Amazon Fire Stick to 5 GHz instead of 2.4 GHz?
Message 33 of 46
Thanks @KeithFrench  🙂
Message 34 of 46
Hi @JoeBullen
Channel 155 is most likely the issue, most WiFi adapters in devices cannot use this channel. There is a fix for this from Eero that needs to be applied & it looks like @Anonymous already has this in hand.
Message 35 of 46
Hi Joe,
Thanks for the additional information and I'll pass this over too.
Message 36 of 46
Thanks Michelle
Message 37 of 46
Channel: 155
Control Channel: 149
Channel Bandwidth: 80 MHz
Message 38 of 46
In the Eero app, under Radio Analytics, what is the 5GHz channel number shown?
Message 39 of 46
Hi Joe,
Thank you. I've asked our Devices Team now and will post back here as soon as I receive a response.
Message 40 of 46
Hi Michelle,
Thank you for getting back to me.
My Amazon fire stick does work on the 2.4 GHz signal however it works suboptimally and I keep getting notifications coming up on the Amazon fire stick telling me to use a 5 GHz signal which my router does emit.
