Eero and tv box
cats6
Message 5 of 5
How near does week and tv box have to be?
4 REPLIES 4
Message 1 of 5
What issued are you having with the TV BOX?
cats6
Message 2 of 5
Not set up yet, just needed a bit of info, thanks.
Message 3 of 5
Are you experiencing any issue with your broadband or TV connection?
Message 4 of 5
There is no rule.
It can depend on a whole hist of things, like your internal walls composition and how many the WiFi signal has to get throught to your TV hub.
As long as your hub gets a reasonably strong signal your apps should work ok.
