Fault with Routers 2.4GHZ Band?
on 13-09-2023 09:21 AM
Message 6 of 6
Hi, I think there is a problem with my router's 2.4GHZ band.
I noticed a while ago that any device that connected on this would have frequent drop outs and be unstable.
I've tried all the usual fixes, disconnecting devices from the wifi, restarting the router, switching off for 30mins, doing a factory reset. I've also made sure I'm using channels 1, 6 or 11.
For a while I've disabled the 2.4GHZ band and everything has been working happily on 5GHZ, but I've just got a new TV which is 2.4GHZ only, so I've enabled it again, and am seeing the same behavior with that, as well as my other devices again now when they try and connect on the 2.4GHZ.
I suspect an issue with the routers 2.4GHZ band, could I perhaps be sent another router to try and prove that one way or the other?
Thanks,
Chris.
Labels:
- Labels:
Connection
Router
Stability
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
5 REPLIES 5
on 17-09-2023 04:38 PM
Message 1 of 6
Assuming that you have one of the Sagemcom router's there is a bug that if you disable and later re-enable a WiFi band, they will not come back correctly. A factory reset is the only way around the bug currently. This might explain the problems that you have had.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-09-2023 12:47 PM
Message 2 of 6
Hi Chris
I'm so glad to hear this.
If you do experience any more issues then please post here and let us know, I can send you a replacement router.
Thanks 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-09-2023 12:29 PM
Message 3 of 6
Hi Debbie, sorry for the delay.
I was sure I had tried a factory reset previously without success, however I tried it again the other morning, and it does seem to be behaving itself now. I'll keep an eye on it and report back.
Thanks,
Chris.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-09-2023 06:45 AM
Message 4 of 6
Hi Chris_J
Did you see my last post? Do you still need help with this?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-09-2023 09:24 AM
Message 5 of 6
Hi Chris_J
Can I just check, have you factory reset the router using the pin hole reset for ten seconds?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- Fibre 65 lagging, discconections, slowing down, throttling? in Broadband
- Router broken or not connecting to the internet - you can still get connected in an emergency. in Full Fibre
- Permanent Logging Fault in Router Fast-5464 in Full Fibre
- Router fault, service department useless! in Broadband
- Router connected but speeds from 0-12mbps in Fibre
